Thread: cam bolt socket size
Results 1 to 6 of 6
  1. #1 cam bolt socket size
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    Need to pick up a socket for the cam bolt is it a 28mm need to know asap
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: cam bolt socket size
    I used an adjustable wrench.
  3. #3 Re: cam bolt socket size
    SE Level Member sco77's Avatar
    MD
    I just threw away my original cam bolt so I cant tell you 100%.. but crank is 21mm and the cam is a few sizes bigger like 24mm, I think I ended up using a 1 or 1 1/16 socket that fit good enough.
    WHAT? How the hell did you torque it?
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  4. #4 Re: cam bolt socket size
    torquing stuff is not always needed. tight is all it needs to be. a dab of loctight goes a long way.
  5. #5 Re: cam bolt socket size
    A dab of locktite and pulled really hard on the wrench lol
  6. #6 Re: cam bolt socket size
    I use a 1 1/16 that I had laying around from something else. Convert it if you want the exact size.
    I tried torquing that bolt to spec. Had a buddy standing on the engine stand. I lifted him, the stand and the motor up onto two wheels. Now I zap it with the air gun. Fuggintight works great, that's the actual spec.
  1. What size socket for rear axle nut (bearing replacement)
    By poopoopeepee in forum Brakes/Suspension/Chassis
    Last Post: 07-05-2013, 04:01 PM
  2. Transmission pan bolt size?
    By quickster in forum General Tech Discussion
    Last Post: 08-05-2012, 01:25 AM
  3. Trailing Arm Bolt Size
    By nault31 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2011, 12:40 PM
  4. Need bolt size assistance
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 03-05-2010, 11:07 PM
  5. Bolt Size
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2009, 06:40 AM
