Thread: cam bolt socket size
Results 1 to 6 of 6
  1. #1 Re: cam bolt socket size
    I used an adjustable wrench.
  2. #2 Re: cam bolt socket size
    SE Level Member sco77's Avatar
    MD
    I just threw away my original cam bolt so I cant tell you 100%.. but crank is 21mm and the cam is a few sizes bigger like 24mm, I think I ended up using a 1 or 1 1/16 socket that fit good enough.
    WHAT? How the hell did you torque it?
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  1. What size socket for rear axle nut (bearing replacement)
    By poopoopeepee in forum Brakes/Suspension/Chassis
    Last Post: 07-05-2013, 04:01 PM
  2. Transmission pan bolt size?
    By quickster in forum General Tech Discussion
    Last Post: 08-05-2012, 01:25 AM
  3. Trailing Arm Bolt Size
    By nault31 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2011, 12:40 PM
  4. Need bolt size assistance
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 03-05-2010, 11:07 PM
  5. Bolt Size
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2009, 06:40 AM
