Thread: Trailing Arm Bolt Size
Results 1 to 5 of 5
  1. #1 Trailing Arm Bolt Size
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    I'm looking for the size of the bolt that connects the trailing arm to the knuckle. I've had UMI arms and new brackets sitting on my shelf for over a year and I finally took on the project. The old craptacular arms are off, but the bolt that goes into the knuckle/hub was a PITA to get off. Since both old bolts are seized to the metal insert of the arm I'm going to try to find new bolts before attempting to cut off these rusted inserts. Does anybody have a bolt size or an idea of where to search?
    I especially would like to find new bolts since these are torque to yield bolts. My first points of search will be Napa and the dealer if I don't hear from anyone tomorrow.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  2. #2 Re: Trailing Arm Bolt Size
    I'll try and measure. But.. why don't you pm me your addy and maybe I'll just send the bolts to you.
  3. #3 Re: Trailing Arm Bolt Size
    I appreciate the offer but I'm looking to get this done today to drive back to school tomorrow. And since everything but those 2 bolts are on I feel pretty close to accomplishment.
  4. #4 Re: Trailing Arm Bolt Size
    I got mine from a dealership. I think they are $8 each or something like that.
  5. #5 Re: Trailing Arm Bolt Size
    I lost the GM part #s but the large bolt that I was looking for is M14-2x90 Hex bolt.
    The dealership did it for me, though they only had one and I was able to hammer the sleeve off of the other one.
    Thanks for the suggestions.
  1. Maf bolt thread size?
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 12:44 AM
  2. 97-03 GTP EGR tube bolt size?
    By AnotherGTP in forum General Tech Discussion
    Last Post: 01-25-2010, 11:27 PM
  3. Trailing arm mount bolt
    By Fourstringsquire in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2009, 04:49 PM
  4. Bolt Size
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2009, 06:40 AM
  5. Exhaust bolt size
    By the1euge in forum General Tech Discussion
    Last Post: 07-11-2008, 09:59 PM
