Quote Originally Posted by 01GrandPrixTURBOGT View Post
Well good luck man I hope its the gasket. I'm gonna try and take mine somewhere and have it looked at cause this is nuts. I've also noticed the car is faster if I don't go full throttle and if I do kr shoots up real high and the car goes nowhere so I've been babying a lot now.
Thanks. I'll let you know if it helps. I agree it's nuts!!! Hope you find your issue to. Might use a couple other diagnosis tools, gasoline and match..
Quote Originally Posted by mkyota1 View Post
Did you plug the exhaust when using the smoke machine? This will let you build some pressure. If not it will go right out of whatever exhaust valves are open.
Noooo. But will now. I don't think the little fog machine I got will put out enough to fill up the motor and exhaust, but will try.. dayumit
