You shouldn't need to cover your exhaust to run a smoke test. Your intake valve should be closed, and if the intake valve is open then the exhaust valve is closed. I did a redneck smoke test. I connected a hose onto the check valve of my brake booster, sparked up a black and mild, then blew every drag into that hose. For the TB, I took a blue latex glove and stretched it over the TB.
