Thread: What is this part on top of my transmission? It is loose & maybe KR culprit?!
Results 1 to 17 of 17
  1. #1 What is this part on top of my transmission? It is loose & maybe KR culprit?!
    Cambridge, Ontario Canada
    It loose & moves up and down. Doesn't thread & bottom seems pushed in which doesn't allow it to be pulled off.
    Uploaded with ImageShack.us
    2005 E55 - stock
  2. #2 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    mine has that too i would say its a breather
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  3. #3 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Yes, that's normal. It would not cause any KR.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  4. #4 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    It just sits there and rattles around?
    2005 E55 - stock
  5. #5 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    Sep 2011
    palm harbor florida
    everything is going to be ok.... just take deep breaths
  6. #6 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    If you calm down and take deep breaths first, I will do the same so you feel better.
    Can someone explain the functionality & purpose of the breather?
    2005 E55 - stock
  7. #7 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    Sep 2011
    palm harbor florida
    im not the one worried about a breather on the trans case lol
  8. #8 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    Quote Originally Posted by Doug 97 gtp View Post
    People ask questions on forums, no? A question does not constitute worry, just clarification & education in this case. Why would I ask a question about a trans case breather if I knew what a trans case breather was?
    2005 E55 - stock
  9. #9 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    I believe that just pops when the trans builds exessive pressure
  10. #10 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    HUDSON
    It is the vent. As the transmission gets hot, the air expands, this vent allows the air to escape while keeping dirt and debris out. Also known as a breather.
  11. #11 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    SE Level Member 2000gtpbt's Avatar
    Mar 2012
    Alexandria, MN
    The only time you half to worry about the breather is when it spiting out trans fluid, then time to get new channel Body gaskets.
    Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
    Albert Einstein
  12. #12 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    Sep 2011
    palm harbor florida
    see elite everything is going to be ok
  13. #13 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    Feb 2009
    flintnasty MI
    about .001% of the time someone thinks they have false KR they actually do. KR denial syndrome.
  14. #14 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    Who said anything about false? There is no false KR (Either in the tune or some "mechanical" problem)
    2005 E55 - stock
  15. #15 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Elite6 View Post
    The thread title............................
  16. #16 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    Still not false, that would be a mechanical issue (if it were truly a problem)
    2005 E55 - stock
  17. #17 Re: What is this part on top of my transmission? It is loose & maybe KR culprit?!
    May 2008
    Schuyler, NE
    Hence false....
  1. transmission cooler line part number?
    By andremike in forum General Tech Discussion
    Last Post: 11-17-2014, 08:31 PM
  2. Culprit found...
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2013, 10:25 AM
  3. The poping noise culprit is.......
    By QUICKSILVER462 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 02:09 AM
  4. Replies: 0
    Last Post: 08-24-2008, 12:43 PM
  5. something seems loose
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 03-08-2008, 01:55 PM
