Thread: Header install question almost done!
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
  1. #41 Re: Header install question almost done!
    Pics or it didnt happen.
  2. #42 Re: Header install question almost done!
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Comin!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  3. #43 Re: Header install question almost done!
    Marysville WA
    Here ya go fellas!
    I took a really quick vid, I have a super nice video camera with an actual mic ill do on a better day but hope you get the picture!
    Heh the left over pile, is it bad that I didnt put the front motorhoist back in? I felt like it just fills space but if its needed ill put it back in...
    And here is the video clip
    ZZP Headers installed on Pontiac Grand Prix preview - YouTube
  4. #44 Re: Header install question almost done!
    Florida
    ah <doggy poo> "The Wife!" lol good job man. congrats. the stalling is prob the fuel trims trying to relearn. did you pull the battery during the install to reset the trims? with the diff amount of flow and new location of the O2 sensor the trims could have changed a bit.
  5. #45 Re: Header install question almost done!
    the stock manifolds dont look restrictive at all...i swear all the header hype is in the downpipe size and that's it.
  6. #46 Re: Header install question almost done!
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    lmfao "okay im done cause theres the wife" thats funny. car sounds extremly nice man good job
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  7. #47 Re: Header install question almost done!
    Good job best it was worth the hassle after its all said and done
    04 Comp G.
  8. #48 Re: Header install question almost done!
    Stock manifold doesn't look restrictive? You must not have ever seen one up close
  9. #49 Re: Header install question almost done!
    seen plenty up close. even had a ported set.
  10. #50 Re: Header install question almost done!
    Marysville WA
    I cant attest to what Bio is sayin he knows way more then me, but I sure do feel a difference, the note is very noticeable from the engine bay the ZZP headers seems to less restrictive then the manifolds I wish I took a side by side picture but they are not goin anywhere!
    I will pull the negative and reset the trims. I am looking for a local tuner. Not sure if I can wait for Will.
  11. #51 Re: Header install question almost done!
    Marysville WA
    So im getting so pretty good vibrations while stopped at a light. Im assuming its my dog bone mounts as when I tried to flip them they got pretty thrashed.
    My question is should I get the shortened dogbones while im at it im doin a ZZP order.
    This is what im thinking...
    http://shop.zzperformance.com/store/...or-Mounts.aspx
    http://shop.zzperformance.com/store/...-Dogbones.aspx
    Might do my subframe bushings as well but I was hoping to not have to crawl under there just so soon. Any other ideas of whats causing the vibrations?
  12. #52 Re: Header install question almost done!
    You can just flip your motors mounts or go with Polys. My suggestion is to avoid ZZP 2 piece design and go with Intenses instead. I had noises and huge clanks with ZZPs. Changed them out for Intense and boom all is well. I would use cradle spacers instead of shorter dogbones.
    04 Comp G.
  13. #53 Re: Header install question almost done!
    Marysville WA
    When you say "cradle spacers" is that the same as motor and trans mount spacers? Like the ones from Vinnie?
    Does anyone else have a say in ZZP vs Intense dogbone mounts? And what about the shortened dog bones? Not doggin ya Redcomp just want to learn of other opinions, ive already got the Intense mounts in the basket!
  14. #54 Re: Header install question almost done!
    Yes the same one that vinnie sells
    04 Comp G.
  15. #55 Re: Header install question almost done!
    Marysville WA
    Good thing I got a set! What do you think about replacing my stock motor and trans mounts to polys?
  16. #56 Re: Header install question almost done!
    I just stuck with hydraulic replacement (or solid if you can find some that's actually solid) when i changed mine. I didn't want any vibration and with just the uppers being poly I didn't have any movement.
    04 Comp G.
  17. #57 Re: Header install question almost done!
    Marysville WA
    Any recommendations on where to find Solid mount? I would like to keep the ride as smooth as possible.
  18. #58 Re: Header install question almost done!
    I know guys were mentioning napa but their 'solid' mounts are sometimes hydraulic so a lot of guys will drill into them to verify if they're solid or not and then fill them themselves. There's a write up floating around here somewhere let me see if I can find it
    04 Comp G.
  19. #59 Re: Header install question almost done!
    04 Comp G.
  1. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  2. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  3. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  4. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  5. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
