Thread: Weird vac/boost problem with BBV and or Actuator?
Results 1 to 2 of 2
  1. #1 Weird vac/boost problem with BBV and or Actuator?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Last month I bypassed the Boost Bypass Solenoid so the actuator was running off pure vacuum (trying to fix my low boost problem), well this morning I decided to hook up the BBV again to see if I still got my 8lbs of boost (I did). While doing this im looking at my vac gauge and with the BBV capped off running the S/C on just Vac I get a good 21 in Hg (idle), when I hook the BBV to the actuator (how its meant to) I get 17.5 in Hg (idle). After I give it a little throttle and let it get back to idle speed it will stay at 21 in Hg for about a second and go back to the 17ish. So I thought boost actuator has a leak, sprayed carb cleaner around it and no change. Where the F*** am I loosing this vacuum at? Thanks in advance to anyone who can shed some GP knowledge.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Weird vac/boost problem with BBV and or Actuator?
    May 2013
    Florida
    I wanna know too
  1. Boost Bypass Actuator
    By fri3dchick3n in forum General Grand Prix Discussion
    Last Post: 08-14-2013, 05:47 PM
  2. Need help!~ with bypass valve boost actuator
    By dreama in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 09:22 AM
  3. P0140 code and boost gauge acting weird
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-14-2009, 07:50 AM
  4. weird problem???
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2009, 12:44 PM
