Thread: Bad vibration after header install
Results 1 to 20 of 20
  1. #1 Re: Bad vibration after header install
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    not sure....did u check and make sure u have everything locked down tight.. i know i left one of my motor mounts hanging off i ( luckily noticed b4 i started it up) ..i would just doublt check everything.....and dont worry after i installed my headers and my exhaust my car sat for 2 weeks b4 i could drive it because i ripped a vacume hose and couldnt figure out y my car was running like shiot...
    180 t-stat, wizaired cai, s&s headers, 3inch cat back exhaust,jpg plug wires, auto lite plugs, 3.4 pulley, and ovk pcm......rockers to come............next summer might go intercooled
  2. #2 Re: Bad vibration after header install
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Yep everything is torqued down tight.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  3. #3 Re: Bad vibration after header install
    Jul 2008
    Dekalb, IL
    The fins from the cat are kinda close to the heatshield, but if it was from that hitting would it really make my car vibrate as bad as it is?
  4. #4 Re: Bad vibration after header install
    Feb 2008
    newyork
    hmmmm ....... i got the same headers and i just did them about a month ago......i dont see y it would be vibrating.... all i know is for me it was a vacume hose the size of a tooth pick and it made my car run real crappy to the point were i didnt drive it or start it up for 2 weeks....idk im sure someone else will give u some better answer so just wait till tonight when everyones on lol
  5. #5 Re: Bad vibration after header install
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by kingd44 View Post
    Lol same thing happened to me. Did it happen to be the one that plugs into the underside of that thing on the back fuel rail ?
  6. #6 Re: Bad vibration after header install
    Feb 2008
    newyork
    hmm not sure there was one on the side by the fuse box and then there was one in the front lol....i was o god what did i do to my car lolol....it made me regret modding for a sec ..but then once everything is fine again i love it lol..im done for a lil bit till next summer...
  7. #7 Re: Bad vibration after header install
    Jul 2008
    Dekalb, IL
    Anyone know if the front O2 sensor resting on those metal lines is a problem?
  1. vibration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:24 AM
  2. 01 GT Vibration in Front Right End
    By sweard2003 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 08:57 AM
  3. 01 GP gt bad vibration when cornering right
    By 01RedfireGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2008, 05:28 PM
  4. Please help with Vibration Problem
    By John_Shughart in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2008, 09:57 PM
  5. Step by Step header install.. HELP!!!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:51 PM
