Thread: Where did my power go??
Results 41 to 60 of 66
  1. #41 Re: Where did my power go??
    wow, something made it from the gas tank, all the way through the fuel lines and rails, and ended up in the return line? holy moly.
  2. #42 Re: Where did my power go??
    Feb 2008
    San Diego, CA
    Maybe not one something, but a lot of little somethings forming a clot. Kinda like arterial sclerosis of the fuel lines.
    I think the return in the tank has a little screen on the end. Maybe that's all fouled up.
  3. #43 Re: Where did my power go??
    Nov 2008
    Central NJ
    Hold everything. You're dealing with a newbie on this fuel thing. In my head the fuel would come from the pump and go first to the regulator, then the rail and then return to the tank. Well since this is what I thought, I was trying to blow air into the supply and not the return. I figured this out the hard way when I turned the key and fuel came shooting out what I thought was the return line.
    Now that I have this figured out, I removed the real return line and ran a hose from the return line to a gas can, started the car and it was running at 48psi. When I disconnected the return line i could hear the faint sound of the fuel spilling back into the tank. I blew some compressed air (45psi) into the line and I could hear bubbles in the tank. I raised the pressure up a little(80psi) and it didn't seem like there was a larger amount of bubbles since there was alot more air. I reconnected everything and I was back to where I started. 90psi.
    I'm going to double check the return line again tonight to see if I see any kink or damage but I'm pretty sure there wasn't any from when I checked it out the other day.
  4. #44 Re: Where did my power go??
    Feb 2008
    San Diego, CA
    So are you saying that you did not get the high fuel pressure issue with the return line leading to a gas can?
  5. #45 Re: Where did my power go??
    Nov 2008
    Central NJ
    Quote Originally Posted by agrazela View Post
    That's right. When I had the return line draining into a gas can while the car was running, I was getting a reading of 48psi. The line did drain when disconnected back into the gas tank but I'm guessing it may be a partial blockage.
  6. #46 Re: Where did my power go??
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    Sweet sound like your on your way to fixing your problem
  7. #47 Re: Where did my power go??
    Nov 2008
    Central NJ
    I checked under tha car again to inspect the entire length of the return line starting from on top of the motor to where it goes on top of the gas tank. I did not see any damage or any sign of a possible kink in the line.
    I did see directly above the fuel filter there is another quick connect where it changes over from a steel line to a rubber line. I'm thinking of disconnecting this and do the pressure tests again using a gas can to catch the returning fuel. I'm just a little concerned that when I disconnect the 2 lines, gas will start syphoning out of the tank since the hose is lower than the tank. Any suggestions?
  8. #48 Re: Where did my power go??
    Feb 2008
    San Diego, CA
    Siphoning will not happen. The return inside the tank opens at a higher point than the level of the fuel.
    x2, I think you're close to finding it.
  9. #49 Re: Where did my power go??
    Nov 2008
    Central NJ
    I thought I heard bubbles when I put the compressed air into the return line. That would show the end on the line is submerged. I also have 3/4 of a tank so maybe I'll burn some off first and then try it. Thanks
  10. #50 Re: Where did my power go??
    Nov 2008
    Central NJ
    You were right. Just a small trickle of fuel came out.
    When I disconnected the return line next to the fuel filter, I routed it to a gas can to see what I would get with the pressure. The pressure was high again. The gas was barely running into the gas can. I then disconnected the quick disconnect on top of the motor and tried to put some compressed air in to drain whatever fuel was still in the line. The gas was again barely running into the gas can. The good news is it appears the blockage is somewhere between these 2 points. The bad news is now how do I get to the exact problem. I looked over the line again and I still don't see anything that may be causing it. There is 1 more quick disconnect but its buried under the master cylinder and I don't think it accessible from underneath. Any suggestions?
    Does anyone have the phone# for Roto-Rooter?
  11. #51 Re: Where did my power go??
    Feb 2008
    San Diego, CA
    I'm sure the book would say to replace the entire return line...$$$
    Are you sure there's a disconnect down under the MC? I'd think it's just a nylon-to-steel "overlap joint" transition.
    Maybe spray half a can of carb cleaner into the line and try to blow some air through it? Or maybe get a tiny little funnel, pour half a bottle of injector cleaner into the line, let sit overnight, then blow it out?
  12. #52 Re: Where did my power go??
    Nov 2008
    Central NJ
    I was assuming there would be a disconnect down there since all of the transitions were disconnects. If it's not a disconnect then that would make it even harder to try and open it up and test each piece seperately.
  13. #53 Re: Where did my power go??
    Nov 2008
    Central NJ
    I just checked with the dealer and it seems to be 1 piece and it sells for $103. I'm still going to look into unclogging it before I spend the $ on a new one.
  14. #54 Re: Where did my power go??
    Nov 2008
    Central NJ
    Does anyone want to buy a slightly used GTP?
    I just changed the return fuel line and I still don't have the power I should have. I do have the correct fuel pressure so it seems that there was definitely some sort of clog in the old line. I haven't had a chance to rip the old line apart to see what the blockage was. I was almost hoping my car would fall on me so I can be put out of my misery.
    Any ideas on what is causing this.
  15. #55 Re: Where did my power go??
  16. #56 Re: Where did my power go??
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    any more progress? don't give up even tho i know your pissed..
  17. #57 Re: Where did my power go??
    Nov 2008
    Central NJ
    how good does your tune look?
    I don't have any mods on the car and I never had anything done to the tuning. I wish I knew someone in my area that I could take this to so I can have another set of eyes look it over. Does anyone know of anyone in Central NJ area?
    My brother-in-law helped me with this latest project with the fuel line. He thinks my small exhaust leak in my resonator would be causing this. Do you think a small leak in the exhaust would cause this much of a loss of power?
  18. #58 Re: Where did my power go??
    does it still bog out? is your cat or resonator clogged? may be your next thing to look at.
  19. #59 Re: Where did my power go??
    Nov 2008
    Central NJ
    Yeah, it still bogs down. When I was under my car, I tried to get a good look at the resonator and it looks like it rusted on top and has a hole. I stopped by a Midas shop to get a price to replace te resonator it would be $270 and to eliminate the resonator it would be $190. The guy was pissed when I said I would have to think about it. I'm going to look into doing it myself and probably next weekend.
    Th cat was changed aound 3 months ago and there was no change in the performance.
  20. #60 Re: Where did my power go??
    that seems like a lot of money to do that. i wouldnt pay over $100 for a piece of pipe to get welded in. i would hit the resonator first and see if that helps you out.
  1. Without power again
    By Rocket468 in forum Off Topic Discussion
    Last Post: 04-21-2011, 12:50 AM
  2. Need more N.A power
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 01:32 AM
  3. tcs off = more power ??
    Last Post: 08-29-2008, 01:44 AM
  4. Need more power help!!!
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2008, 09:02 PM
  5. Power Cut off
    By bburrows in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 05:07 PM
