Thread: I needs picks of engines with a full size I/C.
Results 1 to 20 of 21
  1. #1 I needs picks of engines with a full size I/C.
    Slower, Lower Delaware
    I'm particularly interested in what you did with the coil pack. ZZP's pics don't show enough for me. And if you have a turndown, what you did with the CAI. Also anyone using the alternator bracket kit from ZZP. Did it fit OK?
    TIA
  2. #2 Re: I needs picks of engines with a full size I/C.
    most seem to put bolts under the icm to lift it out of the way. billboost did a how to grind the strut mount to move the coils over, you'll need to search his name for it tho.
  3. #3 Re: I needs picks of engines with a full size I/C.
    Thanks, I try to search for that too.
  4. #4 Re: I needs picks of engines with a full size I/C.
    Thanks again. I found it. I'll look in that section first next time. Sometimes I think Bill has already found the cure for everything.
  5. #5 Re: I needs picks of engines with a full size I/C.
    Johnstown, NY
    Or you could do what Anthony Smith did, and move the coilpack to the firewall.
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  6. #6 Re: I needs picks of engines with a full size I/C.
    Apr 2011
    Vassar, Mi
    I vote move the coil packs to the fire wall, free mod! Then come off the IC plate with molded 90's. The ones I used had 5/8ths on one end and 3/4 on the other so it fit tight on the IC plate hose barbs.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  7. #7 Re: I needs picks of engines with a full size I/C.
    I'm still in awe that I hadn't heard of many others doing what Anthony or I did in the past.
  8. #8 Re: I needs picks of engines with a full size I/C.
    That is a thing of beauty. I'll try to use those ideas. I'm out of commission now. I fell on my wrist and can't turn a wrench for a while.
    Quote Originally Posted by Anthony Smith View Post
  9. #9 Re: I needs picks of engines with a full size I/C.
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    I was interested in doing something like that. Do standard length wires still fit?
  10. #10 Re: I needs picks of engines with a full size I/C.
    Anthony, How big a job was it making the feed wires to the coils reach?
  11. #11 Re: I needs picks of engines with a full size I/C.
    Quote Originally Posted by Sudden View Post
    it's probably something like 2 foot of splicing the whole wire set. not difficult, but it'd take a little time to do it nicely.
  12. #12 Re: I needs picks of engines with a full size I/C.
    That's what it looked like to me.
  13. #13 Re: I needs picks of engines with a full size I/C.
    Pennsylvania
    Moving the coil pack is definitely pretty. But it's probably easiest to just stick a stack of washers under the thing and call it a day.
  14. #14 Re: I needs picks of engines with a full size I/C.
    Apr 2011
    Vassar, Mi
    I didnt move the coil to clear the belt, with the WBS belt wrap kit the belt clears just fine. I moved it so i could route the IC hoses straight out the front instead of the janky way through the belts. It probably took 2 hours to remount the ICM, solder and extend the wires for the coil. I just flipped the plug wires, the long wires that were on the rear went to the front instead. The short front wires go straight down to the plugs on the rear bank, they ended up being a little long so I zip tied them up behind the motor to keep them from melting off on the rear header. Also if you notice I moved the big connector that sits on the front of the supercharger and ran it around the other side so there wasnt sitting right out front covering up my $400 PRJ rails. over all I spent one night of work on the wiring. It's definitely a clean custom look, no one else at the big Detroit meet had anything similar. All the IC cars there had the hoses run through the belts, some of them you could see rub marks where the belt had made contact with the hose. The exact reason I would never run them like that.
  15. #15 Re: I needs picks of engines with a full size I/C.
    It looks like to me, I don't have the belt on yet, that I'll need to reroute the hoses anyway. I love your ideas and I can take the time to do it as soon as my body heals from falling on the steps to my deck. I'll just drive my pickup until then.
  16. #16 Re: I needs picks of engines with a full size I/C.
    I would just be paranoid about cutting the factory wire harness anywhere.... screw one thing up and you have problems. But then again, my confidence in anything electrical is slim to none. That looks incredibly baller.
  17. #17 Re: I needs picks of engines with a full size I/C.
    Anthony, Did you make that plate holding the hoses?
  18. #18 Re: I needs picks of engines with a full size I/C.
    Apr 2011
    Vassar, Mi
    The plate under the hoses is the stock coil pack mount, the hold down is a cushion clamp.
  19. #19 Re: I needs picks of engines with a full size I/C.
    Thanks
  20. #20 Re: I needs picks of engines with a full size I/C.
    Any one use the ZZP alternator relocation brackets? What belt did you use after that? It seems to need to be 2" or so longer.
  1. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  2. PRJ rails and full size IC...
    By whitelightnin04MC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2009, 03:57 PM
  3. should of bought the full size ic
    Last Post: 07-20-2008, 07:27 PM
