Thread: what for mods should be done first?
Results 1 to 11 of 11
  1. #1 what for mods should be done first?
    May 2013
    fayetteville
    i plan on gettin a 98 pontiac gp gtp with 182k on the clock it just needs a steering rack.
    i plan on making it my own as no vehicle i own is stock my question is what should i do and dont do u just say yes or no
    im gonna change all fluids asap from AT to Supercharger oil and diff
    180* t stat
    straight pipe/s
    3.5-4 pulley
    intake
    any other suggestions are welcomed
  2. #2 Re: what for mods should be done first?
    Yeah.
    Suggestion: research.
    Here, http://www.grandprixforums.net/safel...0-a-67580.html
  3. #3 Re: what for mods should be done first?
    May 2013
    fayetteville
    yea i did read that itss pretty informative even a dummy can figure it out
  4. #4 Re: what for mods should be done first?
    Well then, you should know that straight pipes do nothing then, right?
    And that colder temp thermostats do nothing unless you've got a tune.
  5. #5 Re: what for mods should be done first?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    you need to read it again, 3.4-3.5 puller with no exhaust mods (like blue said straight pipes do nothing) is going to make your engine go ,
    at least get tune done..
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  6. #6 Re: what for mods should be done first?
    Get ready for your car to sound like ass.
  7. #7 Re: what for mods should be done first?
    Texas
    Trans and suspension would be the first thing to do. Power is pointless if you can't put it to the ground.
    85 Corvette
    01 TA
    03 Z06
  8. #8 Re: what for mods should be done first?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Not to mention these trannys don't have differential fluid.
    GPONA #1 Cyber Bully
  9. #9 Re: what for mods should be done first?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    In this case, first mod..... Driver...
    Research, research, research...
    180* t stat - Have to have a tune or your motor will actually cool less efficiently
    straight pipe/s - Unless you straight pipe from the manifold back, but it will sound like Honda mating with a donkey...
    3.5-4 pulley - Not without supporting mods
    intake - Won't have any real gains other then you'll hear the blower whine more, unless you do a fenderwell intake
    How much money do you have to spend??? $50, $200, $1,000.... What do you want to accomplish? For the price of a downpipe (new) you can put a little more money with it and get full blown headers. That's mod 2.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  10. #10 Re: what for mods should be done first?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  11. #11 Re: what for mods should be done first?
    Slower, Lower Delaware
    I did a 3" downpipe and a PCM first. Makes a quick improvement pretty cheap. Unless you plan to go to headers soon, then do that and don't waste money on a downpipe for the manifolds. Don't do a pulley with out doing some supporting mods first.
  1. Trade 98 GTP lite mods for GTP with mods
    By Shifty in forum Wanted To Trade
    Last Post: 10-20-2012, 07:52 PM
  2. Mods
    By getsumi shin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2011, 02:33 PM
  3. Mods done.
    By GTP 40TH in forum General Tech Discussion
    Last Post: 07-23-2011, 08:41 AM
  4. First Mods, what should they be?
    By SteelCityTA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2009, 04:57 PM
