So I got my IC pump mounted where I want it now I just need to wire it. I bought a relay/wire kit and want to know the best power source to use. I've read in the past that the best place to power it is via the fuel pump or an injector circuit. With that said, I think I may give an injector circuit a try. So, does anyone know the proper way to wire it to an injector circuit and what color wire in the wiring harness I should be splicing into? There is an injector circuit fuse in the engine bay fuse fox, however there is no room for an ad a fuse
