Ok im gonna try and make this as short as possible.
-swapped cams and everything ok
-did some burnouts and on way home oil light came on
-cold motor 35 psi at idle and 5 at hot idle (checked with mechanical gauge)
What the question is, is if i can band aide the problem by replacing rod bearings and switching to a heavier oil?
right now i use Liqui Moly 5w-30 synthetic
And yes i did change oil before starting engine (im thinking i should've done it twice)
Any input is appreciated![]()
