Thread: Low Oil Pressure
Results 1 to 9 of 9
  1. #1 Low Oil Pressure
    SE Level Member bobeebob's Avatar
    chicago
    Ok im gonna try and make this as short as possible.
    -swapped cams and everything ok
    -did some burnouts and on way home oil light came on
    -cold motor 35 psi at idle and 5 at hot idle (checked with mechanical gauge)
    What the question is, is if i can band aide the problem by replacing rod bearings and switching to a heavier oil?
    right now i use Liqui Moly 5w-30 synthetic
    And yes i did change oil before starting engine (im thinking i should've done it twice)
    Any input is appreciated
    Silver Turd - 1998 ssei XP cam, Gen V, 3.8 pulley, 3.29 gears, intense mail order tune
  2. #2 Re: Low Oil Pressure
    Banned
    Sioux Falls, SD
    Oil Pump?
  3. #3 Re: Low Oil Pressure
    chicago
    I packed that thing full of assembly lube and also primed motor prior to start.
    Ill replace it as a last resort since i don't feel like taking everything apart :/
  4. #4 Re: Low Oil Pressure
    Bob, I am not here to piss in your cornflakes....the reality is.. that motor is coming out and doing bearings often doesn't go well in these motors. They aren't a SBC 350 and they are durable as all hell...right up until you let the smoke out.
    You let the smoke out.
  5. #5 Re: Low Oil Pressure
    Jan 2013
    Australia
    spun cam bearing --> blocked oil feed holes ----> oil starvation
    new cam on old bearings = risky
    stop driving it immediately and rebuild
  6. #6 Re: Low Oil Pressure
    chicago
    And i just finished rebuilding the trans ....looks like ill be looking for shortblock to rebuild, thanks for all the help guys
  7. #7 Re: Low Oil Pressure
    Bob..having been in a similar situation ... the best inspirational advice I can offer is.. "the bolts shouldn't fight." Each time I told myself that one.
    You're right..it doesn't really inspire does it?
  8. #8 Re: Low Oil Pressure
    chicago
    Just realized i never replied haha.
    Turned out to be a spun cam bearing which i thought was rare for 3800's in the states??
    Oh well but thanks for all the help guys
  9. #9 Re: Low Oil Pressure
    Feb 2009
    flintnasty MI
    Quote Originally Posted by bobeebob View Post
    Probably started with crank bearing issues.
  1. No oil pressure
    By 1538brett in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2012, 07:00 AM
  2. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  3. NO OIL PRESSURE HELP !!! plz help
    By shawn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2011, 07:26 PM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  5. Low Oil Pressure?!?!
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 03:07 PM
