Thread: Why am i getting KR?
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Why am i getting KR?
    Yeah that will also cause you to dump fuel. And a quick fix for the cat issue if you have a rear bung for the o2 just do the spark plug non fouler trick.
    Sent from my mobile office.
  2. #22 Re: Why am i getting KR?
    gardner,mass
    Quote Originally Posted by slick2500 View Post
    i cant find a dam non fouler at my work (CAP) i know ive seen them too
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #23 Re: Why am i getting KR?
    Autozone, advance, Oreileys its like $6 p/n 42202 or 42209 which is suppose to be shorter
    04 Comp G.
  4. #24 Re: Why am i getting KR?
    And heads up your probably going have to remove the exhaust donut on side that the o2 bung is on it won't fit with the fouler..easily.
    04 Comp G.
  5. #25 Re: Why am i getting KR?
    gardner,mass
    sweet thanks guys, this with a nice polish and wax today after work
  6. #26 Re: Why am i getting KR?
    gardner,mass
    so how does this or the o2 bung extentions actually work? like how does it trick the rear o2 or pcm to think differently?
  7. #27 Re: Why am i getting KR?
    Quote Originally Posted by Ginseng View Post
    Not a grand prix but the non fouler and 02 part is what you want, and it explains how this works as well. $5 o2 cheater/non fouler how-to - evolutionm.net
  8. #28 Re: Why am i getting KR?
    gardner,mass
    so i fixed my cross over leak and instantly got my mpg up driving around town at 17. Then i unhooked my battery and did the spark plug foul trick and the car seems so much more responsive kr seems to be down.Did a 1/4 pull taking it easy with torque app and hit 15.2 on it, but that was on a curvy road and a slow launch and i let off the throttle once. Car seems to be running better than ever. now its on to the tune and pully drop
  9. #29 Re: Why am i getting KR?
    Woooot. Yea a exhaust leak will ruin your day. Glad I went ahead and did thr spark plug fouler trip prior to you making this thread figured it would be a future issue that came up.
    04 Comp G.
  10. #30 Re: Why am i getting KR?
    Sep 2011
    MI
    Quote Originally Posted by fri3dchick3n View Post
    Bad Lower Mounts might cause KR?
    false KR
  11. #31 Re: Why am i getting KR?
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    i did that non-fouler trick on my sentra se-r back in the day. worked like a champ.
    i have some kr caused by a weak fuel pump at wot. may be something to keep a eye on
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  12. #32 Re: Why am i getting KR?
    gardner,mass
    Quote Originally Posted by TEK310 View Post
    i thought about that but if my af is going from 14.9 to 10.5 at wot that meens im getting the extra fuel i need
    btw guys my mpg went up but i did a pull today and seen 5.9 kr so ima take a look at the lower motor mount cus i feel some slight vibrations in the pedal
  13. #33 Re: Why am i getting KR?
    As I said before you don't have a clue what the real AFR is, only a wideband o2 sensor in the exhaust can tell you that.
  14. #34 Re: Why am i getting KR?
    Apr 2013
    washington
    could the iat in with the maf be heat soaking causing kr and pulling timing?
  15. #35 Re: Why am i getting KR?
    Apr 2013
    washington
    i got overkill in the mail today and the egr and o2 senors were disabled. every problem i have described in other posts on the car is gone not sure why the stock pcm would make this much of a difference unless the egr or o2 was bad but car is now kr free ltft are now right around normal, still a little low but car is perfect. thank you for everyone who attempted to help.
