Thanks for the reply. I removed the EGR valve and throttle body, the tube that connects the EGR valve to the Intake on one side wasn't even finger tight and the end were it connects to the EGR valve bracket there was no nut the tube was just sitting there so to speak. I cleaned up the TB really good also cleaned the MAF. Since napa is closed I wont know if this fixed my problem till it opens tomorrow so I can pick up a new TB gasket. Im also going to pick up a fuel filter, plugs and wires. I should also note on WOT it had a hesitation hopefully this was the reason.
