Thread: 2002 gp gt trans problem.
Results 1 to 3 of 3
  1. #1 2002 gp gt trans problem.
    Jun 2010
    Ohio
    I have a 02 gp gt with 86,000 miles on it. Last saturday afternoon I hit a huge pot hole and ever since the trans has been shifting slow/hanging between shifts and becomes more noticeable with higher rpms. Today I drove it and the shifting seems to be getting worse. I check the fluid level and is in good range and condition but there were air bubbles in the fluid every time I pulled the dipstick. I dropped the trans pan and there isn't any metal shavings or loose part in there and the filter was still where it belongs. Now I am kinda of stuck on what else I can check. I don't have any leaking or loose wires that I can find. I am hoping someone else may have come across a similiar situation. Any help would be appreciated. (and I did do a search first) Thanks!
  2. #2 Re: 2002 gp gt trans problem.
    I think you may have a small leak in the channel plate gasket. Which..is reasonably deep in there. How comfortable are you working on the car?
  3. #3 Re: 2002 gp gt trans problem.
    Jun 2010
    Ohio
    Somewhat comfortable, just not used to working on front wheel drive cars. Is there a way to verify without pulling it apart first?
  1. headlight problem 2002 se please help
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 04-06-2012, 01:02 PM
  2. 2002 GP GT 3.8 N/A Trans Issue
    By GRANDPRIXBANDIT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2009, 09:03 AM
  3. 2002 Regal GS motor/trans swapped into a 97 GTP??
    By toast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 11:05 PM
  4. 2002 gtp trans probs
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-21-2008, 06:44 PM
