Thread: 2002 gtp dic problem
Results 1 to 6 of 6
  1. #1 2002 gtp dic problem
    trenton, on
    hi all,
    just acquired a 2002gtp and the dic/ trip computer is barely visible. you have to get about 2 inches from it to be able to see any kind of display. it would be like dimming your instrument lights down to where you can barely see them lit.. the trac button works and trac light comes on ok, but the rest of the dic is unreadable. all other dash lights and dimmer work fine. checked all related fuses to the system and they are fine. also have the occaisional problem of getting the key out of the ignition, could this be related, considering everything seems to go through the ignition switch. any suggestions would be greatly appreciated.
    thanks in advance.
    john paul
  2. #2 Re: 2002 gtp dic problem
    bulbs need replaced
  3. #3 Re: 2002 gtp dic problem
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    super easy job
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  4. #4 Re: 2002 gtp dic problem
    Sep 2011
    Copperas Cove, TEXAS
    Yup need new bulbs, if you can't replace them yourself there are people on the forum that know how, that's what I did after my bulbs burned out. I got blue LED's installed by a member here.
  5. #5 Re: 2002 gtp dic problem
    trenton, on
    thank you all for your quick replies. haven't pulled the dic out of the dash yet to check the bulbs. hopefully its as simple as a bulb change. maybe i was just over thinking it, making it harder than it really is!!
    keep you all posted.
    thanks
    john paul
  6. #6 Re: 2002 gtp dic problem
    trenton, on
    Quote Originally Posted by johnpstuart View Post
    thanks
    john paul
    update,
    it turned out to be the ignition switch.
    thanks again for all your suggestions
    John Paul
  1. 2002 gp gt trans problem.
    By henry74 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2012, 07:54 PM
  2. headlight problem 2002 se please help
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 04-06-2012, 01:02 PM
  3. 2002 HVAC/Ignition/DRL problem
    By lemaro in forum General Tech Discussion
    Last Post: 10-17-2011, 06:25 PM
  4. 2002 40th Grand Prix Problem...I NEED HELP!!!
    By hoagieman26 in forum General Tech Discussion
    Last Post: 10-14-2011, 10:41 PM
  5. 2002 GTP with Electrical Problem
    By Marc48017 in forum General Tech Discussion
    Last Post: 10-16-2010, 04:58 PM
