yea, this is a great forum... no f***king idiots really... evry1 is pretty chill
Yeah x2 with that, good diversity here. I like it. Seems like this forum is well taken care of too. Sometimes when i post i sound like a jerk off because i completely forget i was a noob too. And i feel like a complete a$$hole when i do that. Sometimes it's needed but most of the time it's definitely not. I just can't wait until i get my hands on this stock gtp i've been eying up. I'm going to prove how far you can take a 3.8 pulley. I plan on beating 50% and more improper 3.4 pulley setups. I was just going to get a 3.8 for my gtp but i wanna do try for 13.80's with a bone stock setup and my killer tuning abilities lol (good luck with that) but hey if it's easy why bother?
yea that would b pretty sick.... but you know, sometimes u need the smaller pulley when you do some mods just to keep up the boost... thats why id say i think after i put some colder plugs, a tstat, n a plog on i should be good to drop to a 3.5 with no kr hopefully, gotta scan...
ohh i don't disagree with that at all, shoot, when i did my rockers and headers i was at 6psi on a 3.4 lol. I tuned it up with 23* of timing and 12.0 afr and it was fast, so i dropped to a 3.2 and re-tuned for that, 21* 11.7 afr (as 12.0 i was getting 1-2*kr and 11.7 i'm not) and it was even faster. I even ran a 3.0 for a while with 18* of timing but the srt-4 i was walking (it was stock, FTL) on the 3.2, suddenly became a good race on the 3.0 after 60ish. I didn't have much top end but man did i have tq up to my azz. I put the 3.2 back in reloaded in the map and i was back to walking away from him to 130 every time lol. I'm going to be on the dyno soon and tuning different setups with my car so i'll be able to see the difference in numbers. hoping for 275ish off the spray and 375-400 with it lol, i dream big!
The whole thing with a colder t-stat is that it keeps the engine a little cooler, yes. But this also will make the PCM add fuel. Thus, your fuel economy will drop. And most of you say" So what, I want performance. And the colder t-stat makes my car run like a raped ape!" Again, I have to ask, do you realize why this is the case?
Most of the time, when someone installs a colder t-stat and they see a performance gain, it is because they had KR to start with. So the increased fuel takes away the KR and thus, their car feels faster. Which it is because it doesn't have KR taking away the timing. So now, you are running more timing than before you changed the t-stat, but also more fuel. So you have your performance back, but you are burning more fuel to compensate.
If you mod correctly, and don't have KR to start with, there is no reason for a colder t-stat. So sticking with a stock t-stat and a correctly modded car with no KR, you can run more timing with less fuel. This not only makes the car faster, but more efficient. So you can have both performance and great fuel economy.
There is a saying with old car guys: "Leaner is Meaner". Meaning the leaner a car is, the stronger and more performance it will have....of course to a point. But adding a cold t-stat is the complete reverse of this. Adding a colder t-stat adds fuel, thus decreasing the performance of a correctly modded engine. The only way a colder t-stat will make an engine run better is if it was modded incorrectly in the first place. Then the cold t-stat is just a band-aid to the actual problem, and does not fix anything.
If did it all over again I would of done away with the tstat. ah well.
like my dad one said once....who cares about fuel economy when your breaking thousands of dollars worth of parts, at the same time his drag car is sponsored by NAPA....lucky a$$.
For a daily driver, even with your mods, a 160°F stat is overkill. You have a tuner, do it right and you will see more gains.
For the track where you are running pass after pass at WOT, I agree a colder stat is needed. But on the street in a daily driver, a colder stat is not needed and is backwards thinking.....especially when you have a tuner.
