Thread: Which t-stat should I get?
Results 1 to 20 of 41
  1. #1 Re: Which t-stat should I get?
    SE Level Member black.gtp's Avatar
    Apr 2008
    Indiana
    Quote Originally Posted by Zef_66 View Post
    The whole thing with a colder t-stat is that it keeps the engine a little cooler, yes. But this also will make the PCM add fuel. Thus, your fuel economy will drop. And most of you say" So what, I want performance. And the colder t-stat makes my car run like a raped ape!" Again, I have to ask, do you realize why this is the case?
    If you tune the car for the colder T-Stat you can keep the same milage and get power gains I am running a 160 t-stat and intercooled car all year and still get good mileage
    PRJ Built enough said!!!!
    www.prjperformance.com
  2. #2 Re: Which t-stat should I get?
    PA
    Quote Originally Posted by black.gtp View Post
    For a daily driver, even with your mods, a 160°F stat is overkill. You have a tuner, do it right and you will see more gains.
    For the track where you are running pass after pass at WOT, I agree a colder stat is needed. But on the street in a daily driver, a colder stat is not needed and is backwards thinking.....especially when you have a tuner.
    2001 GSE
  3. #3 Re: Which t-stat should I get?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Ya a 180* stat with modified fan turn on points is more than sufficient.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  1. 180* T-stat
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 10:30 PM
  2. 180* T-stat
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2008, 06:03 PM
  3. t-stat ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-29-2008, 11:30 AM
