Thread: why do i keep going through motors like candy?
Page 1 of 3 123 LastLast
Results 1 to 20 of 60
  1. #1 why do i keep going through motors like candy?
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Ok so the car is a 99 gt gp and i have a question as to why i keep going through motors so fast.
    I swapped out my motor and transmission from a gt setup to a l67 with the hd tranny. I did a 3.4 setup with headers at the same time of this swap with a tuned ecu
    Now i know these motors are externally balanced via the harmonic balancer and the flex plate . Well when i was doing the swap i noticed the hd trannsmissions touqe converter was in rough shape so i was going to use my gt tourqe converter but this required i use my gt flex plate also i marked were the weiight was on the motor when i swapped the flexplates as too not unbalance the motor but i didnt pay attention to see if there waa any weight difference
    I havent goten an engine to last longer then 1000 miles in this car since this swap so obviously something is wrong here and i want to find out whats wrong because im going to try this one more time before i give up on this. I apreciateany help you can give me and feel free to ask me anything im looking at all options right now. I dont beat on these engines and that whats been stumping me as too why this is happening i mean its not like im putting out a crazy amount of power
    So i was wondering am i unbalancing my motors by doing this and causing stress on the bearings causing my engines to gernade?
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  2. #2 Re: why do i keep going through motors like candy?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    how many engines, where did you get them from, and which bearings.......mains, rods, ?
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  3. #3 Re: why do i keep going through motors like candy?
    Warsaw indiana
    They are the rod bearing that have been going out . It's happened to me with two engines now. The first one was a rebuild and that one lasted for like 900 some miles then it started a rod knock. Now the second one was from a 2002 Gtp with 90k on it . The car was totaled out from rear end damage and that one only lasted 650 miles
  4. #4 Re: why do i keep going through motors like candy?
    Warsaw indiana
    I'm hoping its just a string of bad luck and not something I have been doing because ill really kick myself in the but if it could have been prevented . Twice ...
  5. #5 Re: why do i keep going through motors like candy?
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Quote Originally Posted by Utter99 View Post
    Exact same thing happened to me, TWICE! On the second build, I used a zinc additive with the engine oil, but that didn't help either. After 2-300 miles came the knock-knock...
    These engines are very sensative. I'm on Engine 3 now and finally made it over 500 miles without any issues! Your not alone man...
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  6. #6 Re: why do i keep going through motors like candy?
    Cambridge, Ontario Canada
    Tuned ecu... Hmm...
    2005 E55 - stock
  7. #7 Re: why do i keep going through motors like candy?
    Antioch, IL
    3.4+headers= your situation.
    I hope you prime the hell out of the oil system before you ever start it up......
    2009 Challenger SRT8
    Expert at being gay.
  8. #8 Re: why do i keep going through motors like candy?
    Warsaw indiana
    The ecu is not a problem he is very notable on these forums and I'm sure all you would trust your cars with him.
    And how would headers and a 3.4 have anything to do with how it's being torn up?
    I pumped up oil pressure before I even tried to start it for the first starts on each engine .
  9. #9 Re: why do i keep going through motors like candy?
    Warsaw indiana
    Plus I was only seeing 1-2 degrees of knock at the end of 2nd so the tune and car was set up correctly with that
  10. #10 Re: why do i keep going through motors like candy?
    Antioch, IL
    2°
  11. #11 Re: why do i keep going through motors like candy?
    Warsaw indiana
    Yeah but that would chip a piston before it would destroy a bearing. Or am I missing something here?
  12. #12 Re: why do i keep going through motors like candy?
    Antioch, IL
    I never knocked 8° stock, that must be a **** motor!
  13. #13 Re: why do i keep going through motors like candy?
    Warsaw indiana
    Considering they come with 8* of knock usually from stock I assumed I was pretty safe even considering the more modded you are the more deadly knock is even in smaller amounts
  14. #14 Re: why do i keep going through motors like candy?
    Out West
    8* KR on stock pulley is less dangerous than 2* KR on a 3.4
    Just sayin'
    Whine with your Cheese?
  15. #15 Re: why do i keep going through motors like candy?
    antioch ill
    i have 2 degrees at the most and im stock
  16. #16 Re: why do i keep going through motors like candy?
    Antioch, IL
    Oil or something in the oil, or lack of prep to getting the motor to spin can cause the bearing to fail. Detonation can cause bearing failure. Could be a number of things on your part, or just simply the part you got.
    I replaced my engine with one with 105k. Primed the hell out of it. Primed the hell out of it again. Charged the battery, primed again, then fired. No problems.
  17. #17 Re: why do i keep going through motors like candy?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    My car is stock and occasionally hits 6.5 - 7* KR at top of second.
  18. #18 Re: why do i keep going through motors like candy?
    Warsaw indiana
    I guess it was so basically I'm looking at either its not being primed enough before I start it and I should swap out to a larger pulley ill throw the stock back on and drive it ? I could care less if its modded or not just thought it would be safe to do headers plugs intake thermostat and pulley drop by going off of the safely modding thread .
    So I take it the engine and the balancing issue would have nothing to do with with rod bearing failure and if it was a balancing issue it would be the crank bearings to fail ?
  19. #19 Re: why do i keep going through motors like candy?
    Warsaw indiana
    And Dan I knew some cars knocked more then others . Not just because it could have been bad bad engine like Ihurtz says . It's had factors as such as altitude and temperature
  20. #20 Re: why do i keep going through motors like candy?
    Antioch, IL
    balancing could destroy everything in the engine. To eliminate your end, I would run stock pulley, throw all the supporting mods you want. Drive it. Change oil and filter after 500miles imo as you dont know whats been in that engine. Dont beat it. Drive many more miles. Drop pulley. If goes boom, YOU DID IT!
  1. Old Thread
    By SpeedGrid in forum The Rant Forum
    Last Post: 06-12-2014, 10:03 AM
  2. Replies: 16
    Last Post: 02-20-2013, 10:37 PM
  3. my new candy!
    By JarenSTi in forum Off Topic Discussion
    Last Post: 03-13-2011, 01:14 AM
  4. what motors will go in my 00' GP GT?
    By xNUMNUTSx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2010, 08:30 PM
