Thread: why do i keep going through motors like candy?
Results 21 to 40 of 60
  1. #21 Re: why do i keep going through motors like candy?
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Yes five finger I will defiantly do that also this time around . It just sucks thinking of the people that drive there completely stick car with a smaller pulley and it never does on them. Although its a ticking bomb . I wanted this car to be my daily so I could get ride of the dumb vw passat I have . Just don't feel like I can trust it much anymore . Ill keep her stock from now on till I get out of school
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  2. #22 Re: why do i keep going through motors like candy?
    And I wouldnt even worry about the KR you were seeing, sure any kr is bad, but thats not the main issue here.
    KR doesnt cause spun bearings, its lack of lubraction. KR just break stuff like pistons, wrist pins and stuff like that.
  3. #23 Re: why do i keep going through motors like candy?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    to the op,
    if you caused a imbalence at the flexplate/tc, i would think you would ruin your rear main before a rod saw any harm
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  4. #24 Re: why do i keep going through motors like candy?
    Warsaw indiana
    Thank you five I was thinking that too . It didn't have any correlation from kr to spun bearings on my thought process . I also figured it would have spun a main bearing rather then a rod bearing as the crank would be the one flipping around if unbalanced not the rods.
    I appreciate the input guys . Anyone have any other suggestions ? I am all ears
  5. #25 Re: why do i keep going through motors like candy?
    Jan 2013
    Edmonton, Alberta
    on your "rebuilt engine" did they resize the rods/ change bolts ?
  6. #26 Re: why do i keep going through motors like candy?
    Warsaw indiana
    I let them take the motor all I know is they used .1 oversized on everything after they machined them .
    And I work at napa and we didn't offer the flexplates but thanks for the tip on looking on rock auto . I know the Gtp and gt flex plates will be different because that's why I had to swap them
  7. #27 Re: why do i keep going through motors like candy?
    Jan 2013
    Edmonton, Alberta
    ahahhahaha yeah you said that i guess, whoops
  8. #28 Re: why do i keep going through motors like candy?
    Antioch, IL
    Four KR can spin bearings, go research. Utter id help ya install a replacement engine and get it fired up, but your just a tad to far east sorry.
    2009 Challenger SRT8
    Expert at being gay.
  9. #29 Re: why do i keep going through motors like candy?
    Warsaw indiana
    Is it just the sudden urge of the piston pushing back down on the crank from the kr that makes them spin the bearings? And I appreciate the offer
  10. #30 Re: why do i keep going through motors like candy?
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by Utter99 View Post
    well when crank is coming up vs piston/rod coming down, the bearing is inbetween them,
    in a sence "hammering" them, less then ideal
  11. #31 Re: why do i keep going through motors like candy?
    Warsaw indiana
    Figured that but just wanted to check .
  12. #32 Re: why do i keep going through motors like candy?
    Feb 2009
    flintnasty MI
    sigh... Please stop this discussion on rod bearings from KR... I have done BRUTAL things to motors making 3x the power you guys make and i have never hurt a motor in any way. The fact a guy had a bit of KR a few times will not completely grenade a motor... sorry.
    3800s are very sensitive to clean oil.. the tolerences are very tight on the crank and any amount of water in the oil will quickly kill off rod bearings. The easiest way to prevent these issues is to do a flush oil change after you run the motor for a few miles/ 20 minutes.
    "priming" a motor has very little effect on wear.. while it is a nice gesture 4 seconds of an engine running with sub par oiling is not nearly as bad as running for 1000 miles with the equivalent of no oil.
  13. #33 Re: why do i keep going through motors like candy?
    Antioch, IL
    Never stated 2° blew it. KR CAN spin a bearing. No where did I state its the reason these engines BLOW.
  14. #34 Re: why do i keep going through motors like candy?
    Jan 2013
    Edmonton, Alberta
    whats a tight tolerence iyo
    if this late 80's engine design had tight clearences then why are we useing 5w-30 oil
  15. #35 Re: why do i keep going through motors like candy?
    Warsaw indiana
    So either I'm getting lemons or I'm not priming enough and not ensuring that their is no contaminates in the oil
  16. #36 Re: why do i keep going through motors like candy?
    Don't get a rebuilt motor buy a junkyard one it'll likely last longer.
  17. #37 Re: why do i keep going through motors like candy?
    Out West
    Considering they come with 8* of knock usually from stock I assumed I was pretty safe even considering the more modded you are the more deadly knock is even in smaller amounts
    8* KR on stock pulley is less dangerous than 2* KR on a 3.4
    Just sayin'
    Whine with your Cheese?
  18. #38 Re: why do i keep going through motors like candy?
    Warsaw indiana
    I'm defiantly going to try and find a motor from a jy it's just around here people think that the l67s are just gold . I figured I would be able to find one for less the 500 with less then 150k but . That's really not the case around here .
    So I'm concluding I've just been getting pos motors that where hot roded a lot and porly maintained
  19. #39 Re: why do i keep going through motors like candy?
    Antioch, IL
    I got mine for 500$ shipping was another 200. 105k. was from a impala or something. If you wanna bend over and be almost certain it runs check out morad. Then ur looking at over 1k
  20. #40 Re: why do i keep going through motors like candy?
    You could use an l36 too
  1. Old Thread
    By SpeedGrid in forum The Rant Forum
    Last Post: 06-12-2014, 10:03 AM
  2. Replies: 16
    Last Post: 02-20-2013, 10:37 PM
  3. my new candy!
    By JarenSTi in forum Off Topic Discussion
    Last Post: 03-13-2011, 01:14 AM
  4. what motors will go in my 00' GP GT?
    By xNUMNUTSx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2010, 08:30 PM
