Thread: what motors will go in my 00' GP GT?
Results 1 to 20 of 20
  1. #1 what motors will go in my 00' GP GT?
    Nov 2009
    davisburg MI
    i need a motor for my 00' GP GT. i was trying to figure out what motors and years will go right into my car. what other cars motors will go into ours, and whats the newest year i can put in? i found a 05' 3800 out of a malibu with 40k on it for 900$. will that work? and a good price? Thank you!!
  2. #2 Re: what motors will go in my 00' GP GT?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    3 cylinder 1.0L geo metro engine. $50. if u turbo it u can get 102 fwhp. put an l67 in it.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: what motors will go in my 00' GP GT?
    GTX Level Member bronzemist02's Avatar
    Canada
    Quote Originally Posted by a98gtp4u View Post
    102hp per liter is very good...for a 1.0L. haha.
    I agree. Put an l67 in it. Might want to upgrade the tranny tho if you are going to be wanting to do any mods down the road or want to make it reliable. Well, more reliable.
    ^ That is true. Malibus had the 3.1 not the 3.8. Must have been thinking of that.
  4. #4 Re: what motors will go in my 00' GP GT?
    Jan 1970
    Maquoketa, Iowa
    Basically without much hassle -
    98-03 3.8L grand prix, regal
  5. #5 Re: what motors will go in my 00' GP GT?
    GT Level Member Joe m's Avatar
    mesa,az
    ^lol
  6. #6 Re: what motors will go in my 00' GP GT?
    Wooster, Ohio
    468 bbc. 05 is a series 3, so technically no. Basically any series 2 3800 from 97 to 03 will work out of any w-body with maybe a minor tune on the pcm
  7. #7 Re: what motors will go in my 00' GP GT?
    Donating Users blowfishRus6's Avatar
    g.a.
    malibu is still a series II, the series III only came in the 04+ grand prixs
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  8. #8 Re: what motors will go in my 00' GP GT?
    Wooster, Ohio
    ohhh, thanks for the correction
  9. #9 Re: what motors will go in my 00' GP GT?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    im pretty sure malibus never came with 3800s. i think he's thinking of an impala
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  10. #10 Re: what motors will go in my 00' GP GT?
    Donating Users kfish's Avatar
    Ohio
    like said 97-03 3800 out of a grand prix, lumina, intrigue, etc.
  11. #11 Re: what motors will go in my 00' GP GT?
    Nov 2009
    davisburg MI
    ok since this is an N/A car. how difficult is it to put a l67 in it? if it is realitivly easy i'd rather do that in a heartbeat!
  12. #12 Re: what motors will go in my 00' GP GT?
    you need the PCM and wiring harness for it, otherwise its a pretty straight forward swap.
  13. #13 Re: what motors will go in my 00' GP GT?
    TURBOZ
    NO seriously...boost the crap out of WHATEVER you swap in.
  14. #14 Re: what motors will go in my 00' GP GT?
    Charles City, IA
    Well you have a blower motor,IAC motor, window motors,wiper motor and even possibly a sun roof motor. Any of those will go in with relative ease.
    Everyone else covered your engine options.
    SMGPFC Two Nipple General
  15. #15 Re: what motors will go in my 00' GP GT?
    Buffalo
    l32!
  16. #16 Re: what motors will go in my 00' GP GT?
    Quote Originally Posted by crazyguy03 View Post
    l32!
    lame...who wants low compression?
  17. #17 Re: what motors will go in my 00' GP GT?
    Buffalo
    what does zzp use for turbo builds these days?
  18. #18 Re: what motors will go in my 00' GP GT?
    Ohio
    their ttgt was a high compression l36 i believe.
  19. #19 Re: what motors will go in my 00' GP GT?
    Quote Originally Posted by kfish View Post
    they were running an l67 block on their current records.
  20. #20 Re: what motors will go in my 00' GP GT?
    Buffalo
    increase compression on naturally aspirated and supercharged cars, and for turbocharged applications it is usually a better idea to lower compression because turbos are more efficient at the higher boost levels. Keep in mind that raising compression will increase the chance of KR, so it may require you to run less boost, but you will make more hp per lb of boost.
  1. switch motors
    By dragme in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-01-2009, 06:53 PM
  2. motors
    By noom14921992 in forum Off Topic Discussion
    Last Post: 10-05-2009, 09:13 PM
  3. I have question on motors
    By victorrleo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 09:40 PM
  4. new to 3.8 s/c motors need performance mod help
    By spina74 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2009, 11:39 PM
  5. Galaxy Motors - Victoria
    By WagZ in forum The Rant Forum
    Last Post: 07-30-2009, 12:07 AM
