major cooling problems, and a headgasket failure are about all you can get from this.
Agreed if they are on backwards as in flipped over you might have some issues since the back side of the gasket has the metal ring sitting on the block. If you got the right side or left side mixed up on the spots they were suppose to Go like mine pictured I'm sure you will be ok. Idk if all that made sense.
