darkhorizon
IS4 heads + XPZ = 380whp on 93 octane.
You need RPM and lift to make use of the heads, the extra duration of a xp/xpz makes more power on any head. The only cam that "throws away" power is the IS3/IS4/NIC cam due to its high cyl cleaning overlap... its a tradeoff for low octane fuel.
1.8 rockers may not lose horsepower, but they will not help over stock rockers. 1.7s will increase valve float, and reduce lift over stock, dyno proven loss of at least 5% horsepower.
