Thread: Lots of Codes!!
Results 1 to 20 of 20
  1. #1 Lots of Codes!!
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    I have a 2000 GP with a top swap and xp cam. SES light came on and got it scanned. This is what came up:
    P0108
    P0128
    P0137
    P0327
    P0332
    P0442
    Help me out guys. Thanks
    Steven
  2. #2 Re: Lots of Codes!!
    I live here. DirtDog's Avatar
    Jun 2012
    Hey it helps us help u quicker if u go ahead and Google search each code and post what it is. There's only like 2...maybe just one person with the codes in memory...(billboost).
  3. #3 Re: Lots of Codes!!
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    P0128 is t-stat is it not tuned? P0442 is evap leak
  4. #4 Re: Lots of Codes!!
    Jul 2012
    Kansas city
    P0327 and p0332 is knock sensor codes
  5. #5 Re: Lots of Codes!!
    Jul 2012
    Kansas city
    P0137 is o2 sensor code
  6. #6 Re: Lots of Codes!!
    2 of those are knock sensor codes.
    Another is a O2 code.
    And a MAF code.
  7. #7 Re: Lots of Codes!!
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
    DTC P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulations Temperature
    DTC P0137 HO2S Circuit Low Voltage Sensor 2
    DTC P0327 Knock Sensor (KS) Circuit Bank 1
    DTC P0332 Knock Sensor (KS) Circuit Bank 2
    DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  8. #8 Re: Lots of Codes!!
    May 2012
    Phoenix, AZ
    Thanks for posting all of those Seachicken. I was just about to do so. Any idea how to go about checking all of these? I know there are multiple things possibly going wrong to throw off each of these codes. Any common issues with these codes?
  9. #9 Re: Lots of Codes!!
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    i had a **** ton of codes thrown at me the other day it helps when you have all the wires and plugs plugged in lol
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  10. #10 Re: Lots of Codes!!
    Research each code, there will be some info on how to diag these problems.
  11. #11 Re: Lots of Codes!!
    #1 Give us a bit of information. So far you said you top swapped. Nice, but when? What did you delete or leave on the car? Did you switch evap sensors etc? Did you have the pcm tuned for the swap etc? Who did the pcm?
    See where this is going? I can hop on a forum and say my car won't start. That doesn't tell you that a ran the tank dry and killed the battery cranking it over. You are the guy who knows the car and what/when was done to it. We can't help you without you helping us first. PS, listing the codes and not bothering to look them up... big pet peeve of mine. I'm the kinda guy that teaches you how to fix it.
    Look for things like common grounds or common power.
  12. #12 Re: Lots of Codes!!
    May 2012
    Phoenix, AZ
    Sorry it was vague. I did the top swap with a gen3 about 2 months ago. I had it dyno/street tuned at a nice shop (Extreme Motorsports in tempe AZ). I have all the regular sensors that were on the GT. Big problem was the map sensor since it was from the GT, but they said they tuned around it some how and managed to get 8lbs of boost out of it. I have an xp cam, 42 lb injectors and all the other hard parts required for the xp. Ported heads as well. About a month ago I was throwing a code for a vac leak and a low temp of coolant. Changed thermostat and gas cap(which seemed messed up), coolant temp was fixed, light stayed on for about a week and turned off until last night. All sensors and lines are hooked up to my knowledge by following diagrams. I did bypass the boost bypass solenoid.
  13. #13 Re: Lots of Codes!!
    Ahhh thank you.
    I then see you saying, just recently all these codes popped at one time?
  14. #14 Re: Lots of Codes!!
    May 2012
    Phoenix, AZ
    Yes all at once. SES light came on last night so I went straight to an autozone to get it scanned. Light turned off this morning while I was driving.
    What is scaring me is the 2 knock sensor codes. I have an aeroforce to scan for that and I have 0 knock. Could these sensors be wrong and I'm actually having knock that it isn't picking up?
  15. #15 Re: Lots of Codes!!
    May 2012
    Phoenix, AZ
    sorry I have no idea what you mean by noise channel for 1 and 2? and power/grounds??
  16. #16 Re: Lots of Codes!!
    See if you have the noise channel for 1 and 2 available. I forget if they are in the Aeroforce. If you see noise, then you should be able to scan for knock. However.. Look at the code it set. It's the circuit not the sensor or knock. Which isn't an easy one to set.
    That leads me to wonder about the power/grounds. Hence my post suggestion.
  17. #17 Re: Lots of Codes!!
    May 2012
    Phoenix, AZ
    Something else that throws me off is at the dyno shop I peaked at 8lbs of boost with 255whp. week or 2 later I hooked up the aeroforce and it was reading 3lbs of boost max. BUT I did not touch anything under the hood and did not notice any difference in power. Why could this be? At the shop it was tuned with a 3.4". After seeing 3lbs at home, I threw on a 3.2" and still 3lbs....??
    sorry for throwing so much out there
  18. #18 Re: Lots of Codes!!
    Who put the car together?
    Maybe they scaled the map somehow?
  19. #19 Re: Lots of Codes!!
    May 2012
    Phoenix, AZ
    A guy that my uncle knows, he completely rebuilt his corvette. works on cars for a living from his house. How can the map be scaled?
  20. #20 Re: Lots of Codes!!
    he'd be a good guy to contact.
  1. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  2. Lots of codes, please help.
    By cameron92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2011, 06:06 AM
  3. I haz H2O. And lots of it.
    By squeaks130 in forum Off Topic Discussion
    Last Post: 04-14-2011, 04:52 PM
  4. New Guy with lots of ????'s
    By Scott B in forum Introductions/Noob Questions
    Last Post: 06-10-2008, 11:06 PM
