Thread: Lots of codes, please help.
Results 1 to 20 of 21
  1. #1 Lots of codes, please help.
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    So i took my car into the shop today and had it scanned for the engine light that has been on for a month or so. Here are the codes it threw:
    P0102- MAF signal Low
    P0137- 02 signal low b1s2
    P0440- EVAP CONTROL SYSTEM MALFUNCTION
    P1441- EVAP System Flow During Non-Purge
    P1571- TCS Pwm cyc. no Frequency/sig
    C0450- Ves Activiation circuit open or started to batt
    C0550- ecu malfunction
    C0244- Pwm Delivered torque malfunction.
    Can someone please help me with this mess of codes. Where should i start?
  2. #2 Re: Lots of codes, please help.
    Google
    We also have a list of what everyone of those codes on here...are.
  3. #3 Re: Lots of codes, please help.
    Google.com
    That's a great place. After you start getting the names of them. Then check out searching GearChatter.com for the fsm info on them.
    No..I'm not looking them up, sorry. You found the internet.. gotta help you use the tools available.
  4. #4 Re: Lots of codes, please help.
    set the car on fire and walk away?...
    at least its not a bunch of p03-- codes
    SMGPFC Member #10
  5. #5 Re: Lots of codes, please help.
    May 2011
    Sorry, i will look them up when i get home. Im posting this from my phone. I just figured you guys may have experienced these codes before.
  6. #6 Re: Lots of codes, please help.
    the 400's ones are emissions codes
    no scratch that all of them are, i ment like cat and 02 codes
    SMGPFC Member #10
  7. #7 Re: Lots of codes, please help.
    102...MAF?
    137...o2 sensor?
    440...evap...?
    1441...evap again?
    1571...ABS/Trac...Hub Sensor most likely or cut/crushed bad wires...
    All of the C codes seem to be steering/hub sensor related...I guess...but get to searching...I'm so nice.
  8. #8 Re: Lots of codes, please help.
    SMGPFC Member #10
  9. #9 Re: Lots of codes, please help.
    May 2011
    Thanks, i will look up all these codes when i have access to a computer
  10. #10 Re: Lots of codes, please help.
    Quote Originally Posted by cameron92 View Post
    If your on this site...he just posted a link to it from here...CLICK IT.
  11. #11 Re: Lots of codes, please help.
    May 2011
    I'm at work right now and probably shouldnt be on my phone lol. But i will be sure to check that link when i get home.
    Thanks for the link btw
  12. #12 Re: Lots of codes, please help.
    Feb 2009
    flintnasty MI
    maf + o2 code = blown fuse 100% of the time.
  13. #13 Re: Lots of codes, please help.
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    I had it on my car. I changed my o2sensor and the code never showed after that.
    where is the fuse for the o2??
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  14. #14 Re: Lots of codes, please help.
    happened to me
  15. #15 Re: Lots of codes, please help.
    May 2011
    Quote Originally Posted by biggt View Post
    Id like to know the same thing. I dont have a service manual unfortunately
  16. #16 Re: Lots of codes, please help.
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Sounds like something serious after Googling.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  17. #17 Re: Lots of codes, please help.
    May 2011
    so i put descriptions beside all the codes, is there anything I should start with first? im pretty low on cash so I probably wouldnt be able to tackle it all at once.
  18. #18 Re: Lots of codes, please help.
    Check fuse 21 under your hood
  19. #19 Re: Lots of codes, please help.
    May 2011
    fuse 21 is good.
  20. #20 Re: Lots of codes, please help.
    evap then maf
    SMGPFC Member #10
  1. I haz H2O. And lots of it.
    By squeaks130 in forum Off Topic Discussion
    Last Post: 04-14-2011, 04:52 PM
  2. New Guy with lots of ????'s
    By Scott B in forum Introductions/Noob Questions
    Last Post: 06-10-2008, 11:06 PM
