See if you have the noise channel for 1 and 2 available. I forget if they are in the Aeroforce. If you see noise, then you should be able to scan for knock. However.. Look at the code it set. It's the circuit not the sensor or knock. Which isn't an easy one to set.
That leads me to wonder about the power/grounds. Hence my post suggestion.![]()
