Thread: Loud Grinding noise when cruising
Results 1 to 4 of 4
  1. #1 Loud Grinding noise when cruising
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    So ive had this loud grinding noise for a while now but it has gotten worse. Its a Seriously loud grinding noise when my car is in motion or cruising. Ive had people tell me it could be my hub bearing or axle. The grinding comes from my passenger side of the car. Last time i inspected y axles the boot did have a tear in it and was leaking axle grease. So my question is is it my axle because i know my hub bearing cant be making a loud ass grinding like this.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Loud Grinding noise when cruising
    St. Louis
    I would def. change that axle. And why couldn't it be the hub? It is a bearing after all. I'd change the axle for sure, then see where that gets you. A leaking cv boot is just asking for trouble. Most likely is has slung all the grease from the joint and now it is toast.
  3. #3 Re: Loud Grinding noise when cruising
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    if the grinding goes away while taking a curve to the right or taking a cure to the left while the grinding is occurring and it comes back after the curve...then its a wheel bearing and usually the bearing would be bad on the same side as the grinding going away. good luck. no abs light???
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  4. #4 Re: Loud Grinding noise when cruising
    It's like both. No reason for me to say that, except..if you do both, you should be all set after that.
  1. Loud grinding noise when I punch the gas! (2005 Grand Prix GT)
    By joshuayobal in forum General Tech Discussion
    Last Post: 01-30-2013, 02:47 PM
  2. help! loud grinding noise
    By gpgt04 in forum Brakes/Suspension/Chassis
    Last Post: 12-21-2011, 02:39 PM
  3. Help! Loud Grinding Noise
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 06-03-2011, 10:30 AM
  4. new grinding noise
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 08:07 AM
  5. Tranny Making loud grinding noise
    By redrunner in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2010, 03:14 PM
