Thread: Looking for cam suggestions...
Results 1 to 11 of 11
  1. #1 Looking for cam suggestions...
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Im looking for suggestions for a motor i am building. Im looking at either a S1X with 1.8rr or an IS3 with 1.7rr. I already have 130# valve springs and titanium retainers. Some other info im also adding a gen v and intercooler and headers. Im looking to maximize these mods. I speced the lifts out and the S1X comes out with more overall lift but im unsure about the other differences in the cam. This will be hooked up to a manual transmission. Thanks
  2. #2 Re: Looking for cam suggestions...
    May 2008
    Schuyler, NE
    What are you looking for out of this motor? Max horsepower?
    The IS3 with stock rockers will make more power than either combination you have listed above. That is what I would recommend.
  3. #3 Re: Looking for cam suggestions...
    Dec 2011
    NY
    Im shooting for over 370whp out of this motor. The car isnt going to be a track queen and i do plan on driving it on the street. Why are you suggesting stock rocker ratio over the 1.7s?
  4. #4 Re: Looking for cam suggestions...
    May 2008
    Schuyler, NE
    Quote Originally Posted by transam24 View Post
    If you want that much power, you should probably get the XPZ.
    Stock rockers will give you more lift with higher lift cams than a set of roller 1.7's.
  5. #5 Re: Looking for cam suggestions...
    Dec 2011
    NY
    I would rather have less lift and wear/friction on the valvetrain with roller rockers than the stock ones.
    xpz has proven to make the most power consistantly... the IS3 is not setup for a m90 at all.
    I would be more inclined to the XPZ if I could find more information on it like the specs that arent listed on their website. Why isnt the IS3 not for an m90 car? The IS4 is supposed to be for bigger blower cars
  6. #6 Re: Looking for cam suggestions...
    Feb 2009
    flintnasty MI
    while you may think that the fancy ass roller rockers are indeed way better.. the reality is they are heavier, and produce less lift than stock.
  7. #7 Re: Looking for cam suggestions...
    Feb 2009
    flintnasty MI
    xpz
  8. #8 Re: Looking for cam suggestions...
    Banned
    Jan 2013
    Colorado
    I plan to get the ZZP vs cam
  9. #9 Re: Looking for cam suggestions...
    Feb 2009
    flintnasty MI
  10. #10 Re: Looking for cam suggestions...
  11. #11 Re: Looking for cam suggestions...
    May 2008
    Schuyler, NE
    Plus, I've never seen a stock rocker break or wear out. But, I've seen multiple roller rockers break and wear out.
  1. Suggestions please?
    By Shedd22 in forum Visual/Body Modifications
    Last Post: 06-09-2011, 08:52 PM
  2. Suggestions?
    By Edagimo in forum Audio, Security & Visual Electronics
    Last Post: 06-10-2010, 11:34 AM
  3. n/a gp gt need some suggestions
    By kyleheine298 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2010, 12:26 PM
  4. cam suggestions?
    By 2000gprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2009, 12:39 PM
  5. need suggestions...
    By r33na in forum Visual/Body Modifications
    Last Post: 10-26-2009, 08:53 AM
