Thread: engine issues,please help!
Results 1 to 8 of 8
  1. #1 engine issues,please help!
    SE Level Member CountryBoy's Avatar
    Jan 2013
    Lima Ohio
    I have a 1997 Grand Prix GTP 2 door with the supercharged 3.8L V6,I have puddles of oil on my intake and it's shaking and shuddering when it runs,I have an 8-10 inch vacuum leak somewhere in the system. I dont know where to start can someone help me? the car has 160,000 miles on it right now
    PLEASE HELP!!!!!
  2. #2 Re: engine issues,please help!
    Oil problem is leaky valve cover gaskets.
    I bet you need the intake gasket done aswell.
    Trace vacuum lines and look for cracks, either try carb cleaner to watch for a change in idle or use a smoke machine to find them.
    Shaking could be because the car is in need of a tune up really bad. Start fixing this thing up to make it run good.
  3. #3 Re: engine issues,please help!
    Jan 2013
    Lima Ohio
    i had the car hooked up to a scan tool in class the other day and its running really lean,I believe its because it has such a bad vacuum leak but I'm not sure,it's currently four points away from throwing a code for the engine running too lean
  4. #4 Re: engine issues,please help!
    Check out your vacuum lines and tees
  5. #5 Re: engine issues,please help!
    St. Louis
    And run 91+ octane in it if you aren't. Just throwing that out there once you find your vacuum leaks.
  6. #6 Re: engine issues,please help!
    Jan 2013
    Lima Ohio
    thanks guys,I think for starters I'm gonna get a gasket kit and then I'm gonna put a smoke machine on it to find the vacuum leak/leaks
  7. #7 Re: engine issues,please help!
    Just noticed you aren't to far from me. If you need any help sometime let me know. I'm super busy right now but sometime down the road.
  8. #8 Re: engine issues,please help!
    Jan 2013
    Lima Ohio
    I had it running good,there was no vacuum leak and it was just bad coils and plugs,but now its doing the same thing again after i opened it up to see what it could really do last night, I got the best quality stock coils i could get and i got stock replacement AC Delco spark plugs,my wires seem fine. I could smell burning rubber really bad,I think part of my issue might be that who ever put the smaller pulley on the supercharger didnt get a smaller belt like they should have but I'm not real sure what my whole issue is. any ideas for me?? oh and I'm running 93 octane fuel
    Got Boost?
  1. GTP engine issues please help!!!
    By 03GTP38k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2012, 07:46 AM
  2. Issues with the engine
    By maverickdog8 in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-24-2010, 04:23 AM
  3. Need help with a Sea-Doo, Engine Issues...
    By FastKatt in forum Off Topic Discussion
    Last Post: 07-18-2009, 01:43 PM
  4. engine issues
    By Mikel2k7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2009, 12:24 AM
  5. engine issues ??
    By sal3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2008, 06:24 PM
