Thread: engine issues,please help!
Results 1 to 8 of 8
  1. #1 Re: engine issues,please help!
    Oil problem is leaky valve cover gaskets.
    I bet you need the intake gasket done aswell.
    Trace vacuum lines and look for cracks, either try carb cleaner to watch for a change in idle or use a smoke machine to find them.
    Shaking could be because the car is in need of a tune up really bad. Start fixing this thing up to make it run good.
  2. #2 Re: engine issues,please help!
    SE Level Member CountryBoy's Avatar
    Jan 2013
    Lima Ohio
    i had the car hooked up to a scan tool in class the other day and its running really lean,I believe its because it has such a bad vacuum leak but I'm not sure,it's currently four points away from throwing a code for the engine running too lean
  1. GTP engine issues please help!!!
    By 03GTP38k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2012, 07:46 AM
  2. Issues with the engine
    By maverickdog8 in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-24-2010, 04:23 AM
  3. Need help with a Sea-Doo, Engine Issues...
    By FastKatt in forum Off Topic Discussion
    Last Post: 07-18-2009, 01:43 PM
  4. engine issues
    By Mikel2k7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2009, 12:24 AM
  5. engine issues ??
    By sal3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2008, 06:24 PM
