Thread: Need help with a Sea-Doo, Engine Issues...
Results 1 to 5 of 5
  1. #1 Need help with a Sea-Doo, Engine Issues...
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    So, I got a deal on a "needs work" 1995 Sea-Doo GTS Bombardier
    Starter hits hard, impeller moves slightly when it tries to start, but motor doesn't turn over
    It sounds like it's trying to start & can't turn over because there's a branch stuck in the impeller
    I checked, the impeller looks clear...
    Anyone have any insight, or ideas?
    If I decide to replace the motor, do I have to stay with the 600 or 650 that's in it?
    What about having to stick with a Sea-Doo motor?
    I'd love to get a supercharged motor for it! (Imagine a SC3800 in it, WOW)
    Plate on the engine says:
    Bore: 2x76mm
    Stroke: 64mm
    Capac: 580,7cc
    Thanks for looking, & any help you may be able to offer!
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  2. #2 Re: Need help with a Sea-Doo, Engine Issues...
    Feb 2008
    Rkrd, IL
    I got a reply on eBay about motor swaps
    Dear fastkatt,
    oh ok, 95 580. well 580 parts are a dime a dozen or you can upgrade to a 650 or 720 without any mods. of corce you would need the matching carbs or carb to the motor you go with. I say carb or carbs because the 580 as well as the 650 and 720 comes with single carb or dual carbs from the factory depending on what year model sky is from. whichever motor you go with make sure you get the carb or carbs that go with that particular motor. as far as the electronics, all you would need to do is make sure you check the charging coil/magneto that came out of your engine or make sure the new engie has the same mag as your old one. they come with 3 or 4 wires somethimes 5 but they all have the same bolt patern. the pipe is bigger for the bigger motor but it fits in the same place so make sure you get the pipe that goes to the particular motor you go with. thre is no book that can tell you how to do this, only eperienced tinkering people can help you. but over all it's very duable and people do it all the time. after that you will also need the prop ment to go with the motor/ski you choose to go with. bigger motor, more pitch prop/impeller.
    - chassis_inc
  3. #3 Re: Need help with a Sea-Doo, Engine Issues...
    Jul 2008
    sumter,south carolina
    sea doo forum maybe?
    02 GTP with mods 05 GP for DD
  4. #4 Re: Need help with a Sea-Doo, Engine Issues...
    Feb 2008
    Rkrd, IL
    Ya', I'm checking there as well, but I trust you guys & want your input as well!
  5. #5 Re: Need help with a Sea-Doo, Engine Issues...
    Feb 2008
    Rkrd, IL
    So, pulled the impeller shaft out of the block, still didn't crank
    Pulled both plugs, bone dry (no water), & still no crank
    All that's left is the starter & the block itself
    If it comes to it, do I rebuild, get a 650, or 720?
    Anyone close to Rockford that could help me out?
  1. BOV issues
    By rodman in forum Turbo
    Last Post: 03-27-2009, 09:00 PM
  2. inner tie rod issues
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 02-11-2009, 06:47 AM
  3. engine issues
    By Mikel2k7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2009, 12:24 AM
  4. engine issues ??
    By sal3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2008, 06:24 PM
