Thread: help wont start???
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: help wont start???
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Ok ill try that in a few and ill let you know
  2. #22 Re: help wont start???
    Jul 2010
    middle_1.jpgok there is 2 sets of wires,which set do i use?
  3. #23 Re: help wont start???
    those are on the pump, you test the harness side that you un plug from the pump, hit every pin inside each plug. one may be for the high speed and the other for normal speed.
    if any of the pins light up the test light, you have power back there. and then the pump is suspect for sure.
  4. #24 Re: help wont start???
    Jul 2010
    ok i went outside to push the car back to the carport,i turned the switch over to pull it out of gear,the pump came on,it crunk and is currently running perfect,i didnt do anything to it,but i drove it about 5 miles round trip and put some more gas in it for now,what could be the deal??
  5. #25 Re: help wont start???
    a bad pump will/can work, then not work for a while before it stops working altogether.
    banging on the bottom of the tank sometimes can bring a dead pump back to life, maybe playing with plugs was enough banging on it to spark life back into it.
  6. #26 Re: help wont start???
    Jul 2010
    That's the only thing I did unplug a plug then plug it back up,so do you think that's what it sounds like?
  7. #27 Re: help wont start???
    you'll find out in the next day or so, when it dies or keeps on working. be prepared for it let you down tho. pay that aaa card up lol
    theres even the small chance the plug was dirty and taking off and back on made the plug have a better connection. <<<very small chance.
  8. #28 Re: help wont start???
    What is all this crunking you are doing?
  9. #29 Re: help wont start???
    not the same thing.
    i think he means cranking. lol
  10. #30 Re: help wont start???
    Jul 2010
    I won't be getting it out anyway cause the man that inspects salvaged cars won't approve it and its not all that bad,I got full coverage anyways but I drive it around my house on back roads to not just let it sit up,when I get my taxes back I plan on sinking maybe 1500 hundred in it but idk if itd be worth it yet,I got to replace,headlights,fender,hood,trunk,front and rear bumper covers,taillights and it will look good,then maybe gaskets and belts and get rpm hand fixed and now fuel pump
  1. Car Wont Start
    By Eric Vanek in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2012, 08:56 PM
  2. wont start
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 01:56 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. Car wont start help please.
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 09-07-2010, 10:23 PM
  5. 97' GP GT wont start
    By AREED in forum Introductions/Noob Questions
    Last Post: 08-16-2010, 06:28 PM
