Thread: help wont start???
Results 1 to 20 of 30
  1. #1 help wont start???
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    ok ive got a 00 gp gtp.its been running perfect, however today i crunk it for the 1st time in 2 weeks,it crunk right up and i backed it out from under the carport then turned it off,i went in the house to get my money to go put some more gas in it and iy crunk but died a few seconds later,i was like it cant be out of gas so i went to the store and put some gas in a gas jug and then put it in the car,now it wont start,whats going on????
  2. #2 Re: help wont start???
    check for fuel pressure at the fuel rail.
  3. #3 Re: help wont start???
    Jul 2010
    Ok how do I do that and what do I need,I got a 03 se and I can hear the fuel pump come on when the switch is turned to on but not on the gtp,why??
  4. #4 Re: help wont start???
    try this, its the fuse box under the hood.
  5. #5 Re: help wont start???
  6. #6 Re: help wont start???
    Jul 2010
    Ok dsmuts you didn't say anything but a pic lol and Scotty just bend it flat and then plug it back in?
  7. #7 Re: help wont start???
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Also the battery may be dead.
    1997 Red GTP 182000 miles stock
  8. #8 Re: help wont start???
    Jul 2010
    It's a brand new battery or not hardly a year old
  9. #9 Re: help wont start???
    GTP Level Member simbah's Avatar
    Lala land
    make sure your gas cap is on tight,, I know sounds stupid but you'd be surprised.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  10. #10 Re: help wont start???
    Jul 2010
    It's charged cause it cranks but not turn over but I don't wont to keep trying it cause I don't wont to burn the pump up and if it was a pump will one work out of a se with a 3.1
  11. #11 Re: help wont start???
    Try starting fluid
  12. #12 Re: help wont start???
    yes bend the tab like posted in the pic, put it back in, this sets the fuel pump in hi speed mode. by passes the resistor that may be dead. if it still dont work, then the pump maybe bad, id open the trunk hole and test for poser at the plug with the key turned forward. or have some one turn the key while you are holding the test light.
    the pump swap, best to cross reference the part # first. look up each cars pump, then see if the part # matches.
  13. #13 Re: help wont start???
    Jul 2010
    Can I drive it like this if it works?
  14. #14 Re: help wont start???
    yeah
  15. #15 Re: help wont start???
    Jul 2010
    Ok ill let you know what I found out tomorrow
  16. #16 Re: help wont start???
    Jul 2010
    ok i checked the fuses/relays and swapped the relay out with the one in the se,it still didnt work,theres no pressure at the fuel rail,gas just barely comes out cause the fuel pump isnt working,still wont come on,whats next??
  17. #17 Re: help wont start???
    open the trap door in the trunk. un plug the pump, test for power, if you have power the pump is most likely dead.
  18. #18 Re: help wont start???
    So did you try bending the tab over or did you just replace it?
  19. #19 Re: help wont start???
    Jul 2010
    I tried the bending and replaced and ill go test it for power,is there like a pos and neg in there?
  20. #20 Re: help wont start???
    with a test light, ground the one alligator clip, then touch one pin at a time inside the plug, do not cross them or the fuse will blow.
  1. Car Wont Start
    By Eric Vanek in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2012, 08:56 PM
  2. wont start
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 01:56 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. Car wont start help please.
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 09-07-2010, 10:23 PM
  5. 97' GP GT wont start
    By AREED in forum Introductions/Noob Questions
    Last Post: 08-16-2010, 06:28 PM
