Thread: 99 Gtp problems (stalling while driving)
Results 1 to 15 of 15
  1. #1 99 Gtp problems (stalling while driving)
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    Hi as you read from the title yes ive been haveing this problem for quite sometime now, the first thing is when im driving it just dies out of random theirs no telling when it will die. im very frustrated with this problem.
    things i have replaced (knock sensor,fuel pump,maf sensor,igniton module,supercharger,Egr valve,cat converter,mufflers)
    any help is really apprecatied because this is quite a pain
  2. #2 Re: 99 Gtp problems (stalling while driving)
    Omaha, NE
    o2 Sensor? Checked for vac leaks? Plugs? Wires? Check the alternator? Battery?
  3. #3 Re: 99 Gtp problems (stalling while driving)
    Jan 2013
    west palm
    the alt and battery have just been replaced but i will go look at the rest because it may be the o2 sensor but what excatly will the o2 sensor do because it only stalls after being ran for like 15+ mins never right when i start it
  4. #4 Re: 99 Gtp problems (stalling while driving)
    Omaha, NE
    There's an O2 sensor test that takes about that long, so that could be it. The o2 sensor reads the air/fuel ratio and corrects the air intake via the pcm as necessary. It will be the one in front of the cat, the one after the cat just ensures the cat is functioning properly and does not change the afr.
  5. #5 Re: 99 Gtp problems (stalling while driving)
    Jan 2013
    west palm
    oh ya and its not vacc leaks forgot to mention.
  6. #6 Re: 99 Gtp problems (stalling while driving)
    Jan 2013
    west palm
    so basically if its not running proper it will cause the car to stall.
    How long would it take to replace this?
  7. #7 Re: 99 Gtp problems (stalling while driving)
    Omaha, NE
    You'll need an o2 sensor wrench. Autozone sells them for around $8. If you've got one of those, maybe half an hour.
    You just unplug it, jack the car up, unbolt it from the downpipe, bolt the new one in (without touching the head of the sensor) then plug it in and lower the car. **Let the car cool before you do this to prevent exhaust burns**
    Is your check engine light on? Most of the time a bad o2 will throw a code.
  8. #8 Re: 99 Gtp problems (stalling while driving)
    Jan 2013
    west palm
    no check engine light isnt on and it threw a code about it once before but never after the one time
  9. #9 Re: 99 Gtp problems (stalling while driving)
    Omaha, NE
    I looked into it a bit more and this is more likely the crank position sensor. Here's a thread you can check out.
    http://www.grandprixforums.net/grand...ing-50240.html
  10. #10 Re: 99 Gtp problems (stalling while driving)
    Jan 2013
    west palm
    haha thanks man because i was suspecting it to be a cps ^.^
  11. #11 Re: 99 Gtp problems (stalling while driving)
    Omaha, NE
    Its early in the morning, lol I wasn't thinking right yet.
    Hopefully that takes care of it for ya.
  12. #12 Re: 99 Gtp problems (stalling while driving)
    Jan 2013
    west palm
    i sure hope it does
  13. #13 Re: 99 Gtp problems (stalling while driving)
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    crank sensor??
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  14. #14 Re: 99 Gtp problems (stalling while driving)
    Jan 2013
    west palm
    yea
  15. #15 Re: 99 Gtp problems (stalling while driving)
    Jul 2011
    Michigan
    lol I was suspecting the crank sensor and was asking if you checked it. Probably should have read all the post first lol carry on
  1. Stalling problems
    By knoppsicle in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-09-2012, 01:24 AM
  2. Engine stalling and loss of power while driving
    By LePrix in forum General Tech Discussion
    Last Post: 09-01-2011, 08:32 AM
  3. stalling while driving
    By otonopaz in forum General Tech Discussion
    Last Post: 10-19-2010, 03:40 PM
  4. 01 N/A 3800 stalling while driving
    By j1b1e1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2010, 12:13 PM
  5. Random Stalling Problems - PLEASE HELP!!!
    By teamramrodd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2009, 03:31 PM
