Thread: CNC Heads--Opinions?
Results 1 to 12 of 12
  1. #1 CNC Heads--Opinions?
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    03 GTP 132k, dd
    I've got my car running strong as near stock. Plan is to enjoy it thru the winter, then in the spring start w/ the go-faster fun stuff, beginning w/ headers. I've ruled out a cam, but eventually plan to do MPS & roller rockers. I'm toying with the idea of getting CNC heads, and have a few noob ?s
    1st, for our cars, can the heads be swapped w/ engine in car?
    2nd, what kind of gains might be expected by bolting on CNC heads w/ a modest build (stock bottom end, rods, pistons, etc)?
    3rd, opinions on comparings CNC heads vs. I/C, for the $?
    Thanks!
    The problem that's causing the issue is right there between the seat and steering wheel. It's you
  2. #2 Re: CNC Heads--Opinions?
    1) yes, very easily.
    2) heads without installing a cam isnt going to be utilizing the extra headroom you just gained. get a cam.
    3) if youre not going to cam the car, the intercooler would do you better.
  3. #3 Re: CNC Heads--Opinions?
    May 2008
    Schuyler, NE
    Swapping heads with the engine in the car sucks. It can be done, but it's not much fun. Cleaning the old gaskets off the block is what sucks.
    You're probably looking at about a 10whp gain on a stock car over one with CNC heads. Get and IC instead.
  4. #4 Re: CNC Heads--Opinions?
    Nov 2011
    Chicago
    Thanks for the input guys. cnc heads are not cheap....
    Please confirm stock L67
    cam lobe = .25
    head clearance = .5
  5. #5 Re: CNC Heads--Opinions?
    May 2008
    Schuyler, NE
    You're going to have to be more specific. I don't know what you're asking.
  6. #6 Re: CNC Heads--Opinions?
    Nov 2011
    Chicago
    I'm trying to get a better general understanding before digging around in there.
    What is stock cam lobe lift? .258"
    With a rocker lift ratio of 1.6.
    When shopping for heads, I see ads w/, machined to .600" clearance. For stock L67, what is clearance?
    Also, shopping for yt 1.9 alum rr, the only place I found is intense, and they recommend 90# springs. I've read in many other places 105# are better. Anyone want to chime in?
  7. #7 Re: CNC Heads--Opinions?
    the .6" clearance will allow you to run more lift (rockers or cam, depends). the part you're really looking for is the heads to be ported. the head room is cheap and extremely easy. the porting (the right way) is the expensive part.
  8. #8 Re: CNC Heads--Opinions?
    May 2008
    Schuyler, NE
    Quote Originally Posted by Mr D View Post
    There is a cam spec'sthread on here, I think stickied in this section. That will give you all the answers you need.
    Anytime you are exceeding .515" lift, you either need machined retainers, viton valve seals, or clearanced valve guides. Just depends on how much lift you have.
    I would go with 105# springs, as long as it's not a Comp Cam Spring.
  9. #9 Re: CNC Heads--Opinions?
    Nov 2011
    Chicago
    Thanks again guys,
    I was looking for the .515" lift, read sticky but didn't see it in there.
  10. #10 Re: CNC Heads--Opinions?
    GTP Level Member joe0813's Avatar
    Boston, MA
    if your not camming the car dont even waste your money on heads. just get yours ported instead.
  11. #11 Re: CNC Heads--Opinions?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    put bigger valves in your heads and blend the throat into the port, wont cost much more the a typical valve job
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  12. #12 Re: CNC Heads--Opinions?
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Stonecold0469 Has stage 3 heads an cam for a very fair price buy both and skip the cnc heads my .02
  1. Help on crack heads..need advice on l26 heads
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2013, 10:07 AM
  2. Need some opinions...
    By Raviaan in forum Audio, Security & Visual Electronics
    Last Post: 03-25-2012, 12:08 AM
  3. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  4. I would like some opinions here....
    By GPdude97 in forum Tires & Wheels
    Last Post: 09-20-2009, 07:36 PM
  5. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
