Thread: Supercharger noise
Results 1 to 5 of 5
  1. #1 Supercharger noise
    SE Level Member GTPCrewChief's Avatar
    Jan 2013
    Alabama
    I'm pretty new the world of superchargers and need a little info. I have a 1998 GTP and when I crank it up when it's still cold I get a fairly loud rattling noise from the air cleaner. I have a cold air intake without the box and you can hear it through the air cleaner. As it warms up the noise quiets down considerably but you can still hear it. I have read where this might be the coupler wearing out. Does anyone have any experience with this. I am a mechanic as changing the couple would not be a big deal, I just wanted to know if this is common so I can tear into and change it. Thanks!
    One other thought. I have checked the s/c oil and it the level is fine.
  2. #2 Re: Supercharger noise
    It's all over the place.
    Google
    There are even YT vids changing it. And yeah, it's very common.
  3. #3 Re: Supercharger noise
    Topeka, KS
    Where to get the coupler.
    ZZPerformance - Supercharger Coupler #ZZ-SCCPLR,
    I used to know where some vids on changing it was but basically just suck out the SC fluid. Disconnect Batt. Remove Belt. Remove all the bolts from the snout to the case. Separate. Replace black coupler with green coupler. Repeat previous steps. Replace fluid with new SC fluid from GM. 1hr job tops.
  4. #4 Re: Supercharger noise
    I live here. TLSheff's Avatar
    INTENSE-Racing.com: INTENSE Supercharger Coupler Change Kit
    For options on purchase, but as with ^^^ likely the coupler. search bar at the top, "Coupler" and you should get pages, google replacement and you should be able to find a "how-to". Very easy.
    Only recomendation is USE GLOVES!!! I cannot stress this enough. If you have a female companion and want to touch her for the next couple day, use gloves. The SC fluid will soak in and hellfire and brimstone won't get out that smell.
  5. #5 Re: Supercharger noise
    Jan 2013
    Alabama
    Thanks for the info. I kinda thought that's what it was but wanted to get a good answer from folks with a little more experience. I did find a good write up on changing the coupler.
    How to replace an M90 snout coupler without removing the entire blower
  1. Noise from near supercharger
    By jmackisback in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2012, 12:29 AM
  2. supercharger noise?
    By Owen Shoopman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2012, 09:21 AM
  3. supercharger noise
    By thomas mcnulty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2012, 04:51 PM
  4. supercharger noise
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2010, 06:04 PM
  5. Noise in the supercharger
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 06:58 PM
