Thread: help.... supercharger problem
Results 1 to 7 of 7
  1. #1 help.... supercharger problem
    Dec 2012
    middleboro,ma
    i was driving my 98 gtp today heard a weird sound, it was my belt tentioner pulley breaking off (original plastic one) i got a new one put it on, problem now is it must of hit the supercharger pully on it's flight now i have oil coming out of the pully stem of the charger. can i run the car with out hurting it with the belt off the charger? also is there a seal behind the pully of the supercharger i can replace ? thank for any advice
  2. #2 Re: help.... supercharger problem
    Banned
    Dec 2012
    RichmondHill Queens N.Y.C
    Maybe. With the belt remove.The s/c will still spin during acceleration of the engine.The spining force is produce by the incoming air flow. Check your s/c oil. Low oil will cause excessive wear and tear to the front s/c bearing which required oil. Check the snout seal for damage or leaks too.
  3. #3 Re: help.... supercharger problem
    Dec 2012
    middleboro,ma
    any one know where i can get the snout seal, local parts store have no listing for supercharger parts
  4. #4 Re: help.... supercharger problem
    some one had this problem a few days ago, they found a bolt that fit, rtv'ed the threads, and snugged it up.
  5. #5 Re: help.... supercharger problem
    It might be easier for you to just swap your snout out with one from intense. I think it's only like $50 for a snout.
  6. #6 Re: help.... supercharger problem
    Dec 2012
    middleboro,ma
    just checked intence it is only $50 bucks, the description said it is cut down to fit the smaller pullys, just need to find out if i can run my stock pully on it, also 3800 perfomance has all the parts to rebuild it for $72, 50 would be better if it works with the stock pully
  7. #7 Re: help.... supercharger problem
    that snout will work, its milled to accept the smallest of the small pulleys, the stock pulley will still work just fine.
  1. Supercharger tensioner problem
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2012, 07:45 PM
  2. supercharger problem
    By fremmy182 in forum General Grand Prix Discussion
    Last Post: 07-17-2012, 02:33 PM
  3. big problem with supercharger
    By bstuby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2010, 10:42 AM
  4. Supercharger leak and PSI problem
    By BullittGP1998 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 02:01 PM
  5. supercharger/ horn problem
    By planogtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2010, 07:13 PM
