Maybe. With the belt remove.The s/c will still spin during acceleration of the engine.The spining force is produce by the incoming air flow. Check your s/c oil. Low oil will cause excessive wear and tear to the front s/c bearing which required oil. Check the snout seal for damage or leaks too.
