Thread: help have engine knock.
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 68
  1. #1 help have engine knock.
    SE Level Member twentyocho's Avatar
    Feb 2013
    Amarillo
    Guys have a knock which i thought might be my engine taking a crap but no metal or coolant in oil. No loss of coolant. No oil burning. Cant figure it out. Saw a video on youtube with car making same sound. Guy said oil sending unit went bad. This make sense? If so where's it located and is it hard to replace? Thnx for any help.
  2. #2 Re: help have engine knock.
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    which side of the engine is it coming from? Do you have oil pressure? Might be your flexplate bolts
    97 Bonneville SE Not so much a 97 anymore
  3. #3 Re: help have engine knock.
    Feb 2013
    Amarillo
    Cant pin point it but will check for oil press. asap. Any way to do this fast?
  4. #4 Re: help have engine knock.
    Nov 2009
    Central Jersey
    You have an oil pressure gauge on your dash? The oil pressure sending unit is right above the oil filter. You can hook up a manual gauge there to check pressure.
    Also an exhaust leak could have a knock type sound to it
  5. #5 Re: help have engine knock.
    you can rent or buy a oil pressure test gauge you take the low oil pressure sensor out, and screw the hose from the gauge into where the sensor was, then start the engine up. then read the gauge. at a cold start you want to see close to 50 psi or higher, warmed up at idle you want to see at least 19 or higher psi.
  6. #6 Re: help have engine knock.
    oh, and the pressure sensor in just past the oil filter on its housing, you'll want to take the pass side tire off to get to it.
  7. #7 Re: help have engine knock.
    May 2008
    Schuyler, NE
    Pull your spark plugs out and make sure none are smashed.
  8. #8 Re: help have engine knock.
    When you spin a bearing or get rod knock, it isn't common to see coolant or oil leaking/mixing/missing. None of that is compromised. Possible crap in the oil, yes. Not easy to see on the dipstick all the time though.
  9. #9 Re: help have engine knock.
    Feb 2013
    Amarillo
    Guys im gettin a video up as we speak. just got back so probly not messin with it today but will for sure tomorrow.. From what your tellin me Billboost im not gettin a good feeling. The more i try to listen to it the more I think its coming from the inside of the engine. This sucks I was gettin really attached to this car. Had just ordered new headlights for it dammit..
  10. #10 Re: help have engine knock.
    Jan 2013
    Australia
    could be harmonic balancer mate?
  11. #11 Re: help have engine knock.
    Feb 2013
    Amarillo
    Ok fellas ima try to get vid up.. Here goes..
    <iframe width="560" height="315" src="2000 Pontiac Grand Prix GTP Mystery knock - YouTube" frameborder="0" allowfullscreen></iframe>
  12. #12 Re: help have engine knock.
    Doesn't sound good whatever it is. To me it sounds internal.
  13. #13 Re: help have engine knock.
    make another vid, and rev the engine to say 2500 to 3000 rpm, hold it there for a few seconds then let the gas go back to idle, like just let it drop back.
    the vid you posted kinda sounds like a broken spring, or valve train, "maybe". the 2 nd vid will clear that up for us.
  14. #14 Re: help have engine knock.
    St. Louis
    That really doesn't sound like a rod to me. Have you tried removing the S/C belt and starting it to see if the sound went away, or maybe both belts? If it's not a pulley then could be a rocker.
  15. #15 Re: help have engine knock.
    Feb 2013
    Amarillo
    Guys i really appreciate the responses. Im gonna get a second vid up Scotty and follow your instructions. I will say it seems louder at top than bottom from what i can here. Anyways ill try to have tha vid up early in the AM.. Again i do appreciate any and all feedback. You guys have a great night tonight and hopefully tomorrow that vid will remind someone of something familiar and i can get it fixed.. I will say the wife isnt too happy with the thought of me sinkin money on it considering its my "work" car lol.. But God willing and its within reason i wanna get this car up and running again..
  16. #16 Re: help have engine knock.
    Ohio
    if the sound goes away with when you raise the rpms it is probably the flexplate. you could also get under it and take the inspection cover off and shine a light up on the flexplate to see if you can see if its broken. it does not sound like a spun bearing/rod.
  17. #17 Re: help have engine knock.
    Feb 2013
    Amarillo
    Ok guys got a vid of it while idling then revd up a few times. Revd it up to 2500 then idled then 3000 then idle then 2500 to 3000 then off.. Not thinking its the flexplate as knock is pretty consistent.. Anyways here's the vid as promised hopefully it sheds some new light on the situation... Once again thnx again for all the help fellas..
    <iframe width="560" height="315" src="2000 GTP Engine Knock - YouTube" frameborder="0" allowfullscreen></iframe>
  18. #18 Re: help have engine knock.
    still sounds valve train related to me. id pop the valve covers off and have peek at whats going on there.
    could be a broken spring or something easy to deal with.
  19. #19 Re: help have engine knock.
    Listening right now.
    It's very consistent, very light. If you start up a bad bearing motor and rev quick to say 2500, just a quick throttle blip and let right off, there's typically a distinct banging on let off. Your vid it's consistent. More like one cylinder not firing.
    Do you have a scanner of any sort to look for misfires on one clylinder? Did you do any work to it recently? Sounds too nice and consistent.
  20. #20 Re: help have engine knock.
    Feb 2013
    Amarillo
    Nothing at all. Thats y im baffled cause if it wasnt for noise it actually idles great..
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Engine Knock
    By chrisangelly1981 in forum Introductions/Noob Questions
    Last Post: 01-23-2013, 01:42 AM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
