Thread: Engine noise, then no-start
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Engine noise, then no-start
    Rob...what are you seeing that I'm not? Looks lined up to me.
    It would have been fun to agree with you just to mess with Nick..but he's already got enough work in front of him.
  2. #22 Re: Engine noise, then no-start
    Nick..you might want to consider finding the magnets that LS based engine guys use during a cam install to hold the lifters up. That way you wouldn't have to take off the LIM.
  3. #23 Re: Engine noise, then no-start
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    That sucks man. I would say this is your problem. Why would it chew the key though is my question. I would reinstall the whole valve train. A lifter or pushrod might be getting stuck and causing excess of drag.
    97 Bonneville SE Not so much a 97 anymore
  4. #24 Re: Engine noise, then no-start
    There's always Jason's issue. His lifters overpumped and basically caused an issue. Look up the Hitman Hoopyde thread.
  5. #25 Re: Engine noise, then no-start
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    Take a look at the discoloration of the gear behind the timing set gear, the timing gear has rotated on that shaft.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  6. #26 Re: Engine noise, then no-start
    Shows that it isn't lined up with the balancer drive gear. That's er uh...tough to accomplish.
  7. #27 Re: Engine noise, then no-start
    Oct 2012
    Pinckney, MI
    The balance gear is also the camshaft, correct (Been a while since I've been in there)? If the timing gear isn't lined up properly with that gear, it would mean that the cam timing was off by quite a bit.
    -Rob
  8. #28 Re: Engine noise, then no-start
    Well.. kinda.
    You put the cam with key into the motor. Then thrust plate, after that is the gear to drive the balance shaft. Line up it's dot with the balance shaft dot. Then the cam gear goes on, it's dot is lined up with the crank gear dot. Both the balance drive gear and cam gear ride on the cam together and use the same key to hold their orientation.
  9. #29 Re: Engine noise, then no-start
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Well, I found my problem, but I wish I hadn't.
    1 Crate motor soon to be ordered as the pushrods are bent, valves are bent, lifters are broken and cam bearings are shot.
    FML
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  1. Weird noise on take off, after first start
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 05:17 AM
  2. Weird noise at cold start.
    By WolvesSoulZ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2012, 05:36 PM
  3. Rubbing like noise in D after start up
    By hitnf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-30-2011, 11:40 PM
  4. Clicking noise at start up
    By jokyfo in forum General Tech Discussion
    Last Post: 08-12-2010, 10:44 AM
  5. Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    By alilsassygrl in forum General Tech Discussion
    Last Post: 06-20-2009, 12:05 PM
