That sucks man. I would say this is your problem. Why would it chew the key though is my question. I would reinstall the whole valve train. A lifter or pushrod might be getting stuck and causing excess of drag.
The balance gear is also the camshaft, correct (Been a while since I've been in there)? If the timing gear isn't lined up properly with that gear, it would mean that the cam timing was off by quite a bit.
-Rob
