Thread: Top swap not making power! Help
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 103
  1. #1 Top swap not making power! Help
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    I did a gen 3 top swap on my 2000 grand Prix with an xp cam and all the little things to go with it. Lifters. Valve springs. Ported heads. 42.5 lb injectors. Also on a 3.4" pulley. Its on the dyno and everything is reading good except for the power. Its only making 190 something horse to the wheels and a peak of 4.something boost. Timing is at 15 degrees with 0 knock. The boost reading was choppy going up and down during the pulls instead of a straight line like it should. He bypassed the boost solenoid to see if it would make a difference and it didn't. I suggested that the belt could be too big and slipping causing the boost levels being low and the boost levels going up and down. He checked and thought the belt was too big so they ordered a smaller one. Could the belt size cause that much of a power loss? What else could it be??
  2. #2 Re: Top swap not making power! Help
    Not unless you're running some stupid huge belt.
    The BBV should be dumping to the atmosphere anyways...it shouldn't be in the vac lines.
    What are the injector IPW's?
    AFR?
  3. #3 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Yes I have headers. Air to fuel ratio??
  4. #4 Re: Top swap not making power! Help
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    You have headers too (I'm assuming yes if you have the ported heads) You would hear if your belt was too big. I ditto blue. What is your AFR?
    97 Bonneville SE Not so much a 97 anymore
  5. #5 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    I'm not sure on the numbers. Injectors were 50 some percent. He said all the air numbers and sensors looked good
  6. #6 Re: Top swap not making power! Help
    Yeah.
    Get a scan from the dyno guy...AFR is Air Fuel Ratio, yes.
    Also, IPW's should be less than 19~ honestly. If they are anywhere near that or higher they are maxed out. Which you shouldn't be on 42.5's with that setup.
    Take a pic of the engine bay and post it...see how everything is setup and routed.
    And by choppy...is it cutting out? Sounds like another problem all together.
  7. #7 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    On 15 degrees of timing...AFR 11.8-11.6. INJECTOR DUTY CYCLE AT 6000 rpm was 60%. MAF at 6000rpm was 220 grams per second. Boost max was 5.1 lbs. Average was around 4 lbs. By choppy I meant boost was going from 3-5lbs throughout the run. Going up and down
  8. #8 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Send me your number in a pm I'll send you the pic that way.
  9. #9 Re: Top swap not making power! Help
    needs more boost.
  10. #10 Re: Top swap not making power! Help
    Fuel filter. lol
  11. #11 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Around how much boost should I be running?
  12. #12 Re: Top swap not making power! Help
    Out West
    12psi
    Whine with your Cheese?
  13. #13 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    What else could be causing stock power coming out of this???
  14. #14 Re: Top swap not making power! Help
    First question is it misfiring?
    If no, then is the belt slipping?
    If no, Is the BBV actuator closing during WOT?
    Figure that stuff out first.
    And the solenoid can fail separately from the actuator.
  15. #15 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    No misfiring. I'm thinking the belt is slipping because of the boost levels going up and down like a roller coaster throughout the each run. Not sure about the BBV. how can I tell if its closing?
  16. #16 Re: Top swap not making power! Help
    Out West
    Quote Originally Posted by Steven Monteith View Post
    Could be bbv.
    When i had a bad tensioner, boost levels would "stay low" and seem to cut out at the very top
  17. #17 Re: Top swap not making power! Help
    Remove the hose on the top and cap it off on the vacuum tree side. then go wot.
    If you see more boost, then it wasn't closing and you need a new one.
  18. #18 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    Remove the hose on the top and cap it off on the vacuum tree side. then go wot.If you see more boost, then it wasn't closing and you need a new one.
    Which hose is that? There's 3 hoses coming out of it right? The guy doing the dyno bypassed it by connecting 2 of those hoses. Not sure which of the 3 though.
  19. #19 Re: Top swap not making power! Help
    May 2012
    Phoenix, AZ
    One of the first runs on the dyno the torque maxed out at 350 but the horse was like 170 with 10 degrees of timing and very low boost. The he hooked up the wires differently under the hood then both numbers were around 170
  20. #20 Re: Top swap not making power! Help
    This is discouraging.
    I would like to see what you have connected where.
    Better yet, google L67 vacuum routing diagram and see what comes up.
  1. not making the power
    By sprattzvx in forum PCM Tuning
    Last Post: 10-18-2011, 03:47 PM
  2. Replaced Power Steering pump, now making noise.
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 05-14-2011, 03:06 PM
  3. Possible to swap mirror from standard to power?
    By cboth686 in forum General Tech Discussion
    Last Post: 08-15-2010, 12:45 AM
  4. More Low/Midrange power... without doing a top swap.
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2010, 08:20 AM
  5. Making a L67 RWD...My S10 swap plans
    By Pittman06 in forum Off Topic Discussion
    Last Post: 12-19-2009, 11:38 PM
