Thread: Rebuild L67 questions
Results 1 to 9 of 9
  1. #1 Rebuild L67 questions
    Jun 2012
    south haven mi
    I decided to pull the heads on my L67 this winter cam it,port the blower etc.I think it would be a good idea to put bearings in it also.Besides checking the timing chain tensioner is there anything else i should look for or replace/upgrade?Should i use the upgraded oil pump kit? Any input would be greatly appreciated.Do i need any specialized tools to do what i want to do?
  2. #2 Re: Rebuild L67 questions
    If you pull apart the bottom end, you'll have to check everything and be sure it all goes back together 100% within spec or you'll have a 100 mile engine.
    It's a safer bet to leave it alone unless its that old and tired. In which case a used engine might be a better alternative.
    There is an upgraded oil pump kit now?
    Typically an S III timing cover would be considered an upgrade in terms of oiling.
    Port the heads. Blower porting won't matter much compared to the heads.
    I'm sure this has been answered a hundred times already.
  3. #3 Re: Rebuild L67 questions
    Jun 2012
    south haven mi
    I wanted to have the heads checked atleast and i was going to pull a bearing or two and check them.I was asking if the upgrade kit for thr oil pump is worthwhile or not? I wasnt aware the timing chains had oiling issues i know the tensioners go bad.I will likely clean up the heads a little myself this is a very low buck build and i just wanted to inspect everything and replace whats needed.
  4. #4 Re: Rebuild L67 questions
    I honestly wasn't aware there was an upgrade for the oil pump.
    Unless you're referring to the oil pressure spring. Which apparently is the same as the older ones. Perhaps a fresher spring is why people see more oil pressure? More investigation should be done there. But on the whole, it won't matter.
    The series III timing covers have larger oil feed holes.
    Heads would be well worth spending time on.
  5. #5 Re: Rebuild L67 questions
    Jun 2012
    south haven mi
    Ok Thanks Matt i saw the oil pump upgrade on zzp site i think (yeah i know) looks like just a spring,shim and gasket.Just curious cause i planned to run 5w30 in it.I am not a fan of making huge oil pressure i think its a waste.I asked cause you guys know a lot more than me and the members have went thru these things already and was just curious.Dont want to make any mistakes....Thanks
  6. #6 Re: Rebuild L67 questions
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    I am doing the exact same thing this winter. Have mine down to the block and waiting on parts, cleaning stuff in the meanwhile. I didnt touch the bottom end, but I have ported my blower, and added a block off plate, modded my LIM via BillBoost's thread, and ported my TB along with removing a bulk of the MAF dam. I was previously decided to not port the heads myself and just leave them stock flow, but if I find a decent guide and find the time I may pull out the dremel...
    Also I have headers, MPS, polished aluminum valve covers, new stock timing set, XP cam, shift kit, etc on the way from ZZP!
    Aug 2011
    Millbury, OH
    Rebuilt mine due to a chipped piston. Just going back together now. New bearings, pistons, all done at a machine shop I trust.
    2000 GTP coupe, Stattama Turbo Setup, A/A intercooled, custom cam, Tischler heads, 3250 stall, Zzp trans, 1" GMR chain, 65# injectors MDP hood, MSP exhaust, and much more.
  8. #8 Re: Rebuild L67 questions
    Quote Originally Posted by 88formula View Post
    There is a guide on CGP.
  9. #9 Re: Rebuild L67 questions
    Oct 2012
    West Branch, MI
    Thanks matt! 15% gains from just polishing... thats a no brainer!
  1. Transmission rebuild questions suggestions
    By Beelzeboul in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2012, 02:31 AM
  2. 3.8 performace rebuild questions...
    By Chris Peterson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2012, 03:17 PM
  3. rebuild questions
    By Toms04compg in forum General Tech Discussion
    Last Post: 06-15-2012, 09:23 AM
  4. Engine Rebuild/ Sub questions
    By joliver2011 in forum General Tech Discussion
    Last Post: 11-22-2010, 07:44 PM
  5. Motor & Trans Rebuild Questions
    By BlackGhost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-11-2008, 10:16 AM
