Hey guys,
Thanks for your replies.
@GTP in RTP- Sorry when I listed what I've done with the car so far in regards to troubleshooting I said that I cleaned the IAT but I meant to say IAC. I removed it and cleaned it quite thoroughly removing all the carbon build up. Hopefully cleaning it removed it from the list of possible culprits.
@BillBoost37- I tried unplugging it for a short bit to see if there were any noticeable responses but havent had a chance to drive with the sensor off. I will give that a try here soon and will update to see if your thoughts are correct. Im hoping they areDo you feel it would matter if I ran this test with a cold engine over a hot one? Also, do you think using MAF cleaning spray could help the issue? Please let me know if you have any other ideas you think I should look into and I will keep you updated.
Thanks for your insights guys
-Nick
