Thread: 1998 GTP noise
Results 1 to 12 of 12
  1. #1 1998 GTP noise
    House springs missouri
    when I read the motor it sounds good until I get a little bit past 3000 RP M's I can hear a really fast chattering noise it's getting me creeped out in snot an exhaust leak but the oil seems thin could it be that or not because it doesn't do it Intel around 3000 RP M's
  2. #2 Re: 1998 GTP noise
    it sounds like it's coming from around the middle of the motor in the supercharger area
  3. #3 Re: 1998 GTP noise
    Is this free revving or in gear?
  4. #4 Re: 1998 GTP noise
    both when I free rev and drive it
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Could possibly be a lifter. Try changing the oil.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  6. #6 Re: 1998 GTP noise
    Ok I'll try that
  7. #7 Re: 1998 GTP noise
    It sounds like its coming from the supercharger could it need oil
  8. #8 Re: 1998 GTP noise
    GT Level Member DaytonaGTP500's Avatar
    May 2012
    Iowa
    There's a 3/16 allen wrench plug on the snout (atleast i think its a 3/16) pull it off and the fluid should be pretty dang close if not at the bottom of the threads from the plug. Otherwise thats the only fluid in the charger. Easiest method if u think its the s/c is to pull the supercharger belt off and run it and see if the sound goes away. If it does its prolly s/c coupler and zzp sells a really good one
    May 2011
    United States
    Supercharger coupler usually is only noisy at idle, and its not really a ticking noise.
    Sent from my Droid
  10. #10 Re: 1998 GTP noise
    Sep 2012
    St Louis Missouri
    Could the s/c oil really be causing a problem like this?
  11. #11 Re: 1998 GTP noise
    kind of like a chatter
  12. #12 Re: 1998 GTP noise
    tennessee
    video?
  1. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
  2. 1998 GTP transmission ticking noise
    By Boost2011 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-30-2011, 05:26 AM
