Okey dokey, update time. Car is still acting up big time however I think I made some progress. As per BillBoost37 recommendation to run the car without the maf plugged in triggered the computer to give me a code. Not sure if it was solely because I tried running the car without the sensor or if that assisted in finally putting a finger on what the computer deemed the actual prob was but its a P0171... maf or seal leak. So new maf is in the mail and Im going to check the hoses again and dig around to see if everything is sealed up properly.
In addition to checking for leaks Im planning on Sea Foaming the engine to help clean it out a bit. From your guys experience do you think that if I run sea foam through my car the smoke will come out of a hose if there is a leak or is that all going to go straight out the exhaust?
Im hoping the new maf will help. Ill keep everyone updated once its installed. Thanks again
