Thread: not shifting at boost
Results 1 to 20 of 44
  1. #1 Re: not shifting at boost
    Dirty IAC/MAf will cause skewed shifts.
    Sounds like you got a vacuum leak to me if you tripped a a P0171.
    Especially if you just did the LIM gaskets, did you replace all the rubber "T" fittings?
    Check the MAP sensor on the back of the blower...there should be a port where a "L" rubber fitting goes into the bottom of the MAP that lots of people tend to miss.
  2. #2 Re: not shifting at boost
    GTP Level Member GrandPrixgtp2000's Avatar
    Madrid Iowa
    Whats the IAC, and I just got a new MAF, if you are talking about all the T fittings for the vac lines no i did not change all of those, and the MAP sensor is new too and i have my vac line on that as well.
  1. 07 GP GT not hitting full boost check engine light on tranny shifting hard
    By Wahoo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2012, 08:12 AM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
